Question about Xerox WorkCentre XD100 All-In-One Laser Printer
WorkCentre XD100 The green light is flashing H 4 Or 4 H and will not copy
  • 1 more comment
  • gregory payne Nov 15, 2008
    I would like to be able to download the owners manual because i have misplace my.
  • dflodvm Dec 04, 2008
    h4 flashing o cleaned theh drum and place an new compatible toner not too long ago.
    the conputer continues to display H4 after turned it Off and then OFF and back after few minutes..,
  • Anonymous Dec 29, 2008
    como hago para bajar los driver de esta fotocopiadora
  • 685 Answers
Http://www.nodevice.com/manual/newmans/XD100-102-104smpdf/get11486.html go here
Posted on Nov 15, 2008
Control panel shows "H4"
This is a solution from the Xerox Support website (www.support.xerox.com) Give it a try and hopefully it resolves your problem. Take care & good luck.
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
1. Find the pink Clear button on the Control Panel of the WorkCentre.
2. Find the button below the word Auto.
3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
5. Press the green [Start] button.
6. Press the pink [Clear] button two times.
7. The WorkCentre should now warm up and come to ready.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 03, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
I have a Xerox XD100 black and white copier and it is showing J1 on the display. Wondering what is wrong with it?
J1 is the toner cartridge. Needs to be replaced, printer will not print with a cartridge that is empty.
You can try resetting the Workcentre. Power on, hit "C" then the far left button back and forth 4 times, then enter 14 (like you were going to make 14 copies) hit print. Should clear the code. But if the cartridge is empty the code will return,
Dec 07, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
H-4 model xc830 copier
Performing a Fault Reset 14 will reset your copier and will help to clear error codes. 1. Turn the power off. 2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button. 3. Locate the Auto Button the lower left corner of the Control Panel. 4. Turn the power back on. 5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear. 6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5. 7. Program the copier as if you were going to make 14 copies. 8. Press the green [Start] button to store the reset code. The copier will return to the ready position. 9. Run a test copy.
Jun 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre xd100 copier NO POWER
hi,check power cord if the power cord correctly connected the problem is power supply.
Apr 26, 2009 | Office Equipment & Supplies
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox XD100 does not work
When you saying No working , What Happens when you press the print Button can you manually get this copier to print out ?
Has it stop printing only ?
Feb 19, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
The p lite keeps flashing
You will likely have to replace the feed and seperation rollers.
Feb 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox copier XD100
Does the machine sit there and run and run and run. The motor turns on and just chugs away or simply the ready light flashes? Let me know which symptom so I can send you some things to try.
Oct 22, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Printer
Give this a try, 9 times out of 10 it fixes the H4 problem.
> Support & Drivers > WorkCentre XD100 Digital Copier - Laser Printer Support > How To Clear an H4 Code Solution: Perform a Fault Reset 14 bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Mar 10, 2008 | Sharp AR-M160 Laser Printer
Xerox xd100
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Feb 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
117 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
