Question about Lexmark International Z611 Printer
Paper Jam I have fairly new Lexmark Z611. I recently replced the ink catidges, the thing is when i try to print to paper is being pulled to the right where the roller is and this eventually causes it to jam. Help. It work ok before. Another thing is the first time i used the printer i only had the colour ink .
  • Anonymous May 09, 2009
    It just won't grab the paper. I'm about ready to throw this thing out the window.
  • 351 Answers
SOURCE: Ilost my disk cant install my lexmark Z611 printer
Dear LTTBTL ,
Download the drivers for you Lexmark Z611 printer, from this site:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+Z611
Cheerup and Takecare
Posted on Mar 03, 2008
Maanita
  • 1142 Answers
SOURCE: Lexmark T630
Repeated, Unexplained Paper Jams With Little or No Damage to the Paper ID:ENUS5286 null.gif null.gif null.gif
IMPORTANT: The printer should rest on a surface that is flat, level, and uniform. This is for safety reasons as well as for paper feed reliability. In the bottom left corner on the front of the printer, as well as on the duplexer and each paper feed option apart from the 2000-sheet feeder, there is a shaft that rotates as the main drive motor in the printer operates. The purpose of this shaft (called the Power Take Off shaft) is to turn the pass-through rollers in the option below. The Power Take Off (PTO) shaft rotates during the printer's POR as well as any time the main drive motor turns, including while paper is feeding from any source and when the toner is agitated in the cartridge.
If the printer is on an uneven or non-level surface, the PTO shaft may not make full contact with the bevel gear on the lower options.
If the printer is on a surface that is not uniform (such as a carpet or foam padding), the PTO shaft on the lowest option may catch or bind, causing the paper feed operation to slow or stop completely.
In either case, repeated and unexplained paper jams (with little or no damage to the paper) may occur. The paper jam is due to the increased amount of time it takes the paper to feed through the path because the PTO shaft is bound or caught on the surface below, or is slipping on the bevel gear.
NOTE: This is not a printer defect or failure although it may result in a broken or stripped PTO shaft.
Posted on May 30, 2008
Ajkill
  • 2035 Answers
SOURCE: label sheets won't feed, jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Posted on Dec 22, 2008
yooperbud
  • 8637 Answers
SOURCE: printer says clear paper jam. There is no paper jam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
d2704
  • 101 Answers
SOURCE: 202 paper jam
try to find paper or peice (bit, partm particle) of paper under back cover.
Posted on Mar 07, 2009
I have a brand new ink cartridge in my printer. It printed the test page ok. When I try to print envelopes, it always says paper jam (there is no paper jam) the envelopes just wont feed. It's a Lexmark...
Make sure to set the correct paper setting on the printer or the Lexmark software before sending the print job. Adjust the printer's paper guide to the correct envelope dimension.
Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
Paper jam/ printing problem
I have this printer and when this did it to me like its doing to you the FEEDER had to be replaced. Now you might want to see if all the rollers are rolling and nothing is in the paper path. Also check you paper weight and size and adjust accordenly. A new feeder is like $27 bucks and you would have to go 3rd party to get it. I got mine from a USED lexmark someone was saling off ebay for my fix.
Please be considerate and leave a ratings and postive feedback for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Lexmark X4550 InkJet Printer
HP 5610 printer won't print
Unplug this beast. Take the old ink cartridge out and re-insert. Also, check for any other jammed papers that need to be removed. Then turn this beast back on. See if that does anything old chap.
Feb 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Misfeeds paper pulls to the right--says paper jam-no jam
there could be a paper jam or some paper still inside.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
Alignment error after replacing black ink. Lexmark X5495
I found a pencil inside my printer and took it out. It was not easy but now it does not jams the paper. Disconnect the power cord and softly shake the printer from side to side making sure you are holding on to the top scanner door so it won't flip open and listen for anything rolling or loose inside. It just might be your problem.
Dec 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Won't print
Sounds like a piece of paper is stuck inside the machine. Open all access doors and check. Remove the printer cartridge and reinsert. Make sure the print job has been purged from the queue.
May 31, 2008 | Lexmark X73 All-In-One InkJet Printer
Cartridge problem
in most of the cases the refill will work for a few times then will not work one reason is because the ink gets dry inside the cartridge and second the contacts does not work when you uses that several times and the third the ink is not compatible with the printer no matter if that say for that kind of printer so if you wants to get that right get the new cartridge and end of the problem
Nov 03, 2007 | Lexmark Z600 InkJet Printer
Paper jams
It has nothing to do with cartrigdes. You have an undetected paper jam. You need a pair of tweezers and a torch and need to play lets find the nasty small hard to see bit of paper or ujo (unidentified jamming object) i had a piece of toddler toy cardboard so small once i had to remove it from my roller with a pair of tweezers so don't laugh at me!!! Good luck. Make sure you look everywhere, including inside unit, and down the back where paper goes too. Cheers.
Aug 30, 2007 | Lexmark PrinTrio X75 Printer
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
