There is a breather tube connected to the top of the engine that runs into the top of the carb and is throwing oil into the carb. There is oil all over the carb and top of moter, what causes this?
SOURCE: pulling oil into carb thru right breather
A blown head gasket on an OHV engine will pressurize the crankcase and blow oil out. Make sure that it was not overfilled with oil before tearing anything apart.
SOURCE: oil blow by
A little blow by is normal. Make sure the oil level is correct. If there is excessive blow by, then check the reed valve under the valve cover. It may be damaged or loose.
