Question about Phoenix Gold Car Audio & Video
NO SOUND I HAVE EVERYTHING HOOKED UP AND IM NOT GETTING ANY SOUND.THERE ARE NO PROTECTION LIGHTS ON AND EVERYTHING APEARS TO BE IN WORKING CONDITION
  • b1125209 Nov 15, 2008
    phoenix gold qx4150
    Problem Solver:
  • 6 Answers
First, rule out problems with the wiring to the speakers. Disconnect the speaker wires to the amp. Get a AAA battery. Hold one of the wires to the negative side of the battery and lightly grace the other wire across the positive side. You should be able to hear something like pops and scratches coming from the speakers. Do this for all the speaker wires and wire-tie each pair.
Posted on Nov 15, 2008
Tvand sound comes on but no picture
It is hard to say what the problem could be. A lot of boards on this unit can cause the same condition. Lets start out simple. Can you get the menu to pull up? If you can then check your connections at your inputs and at the components that you have hooked up to the TV. If you can't bring up the menu, then I would suggest having a servicer look at it. You could have a bad tuner causing this, a bad digital board, bad analog board or even a bad light engine. To many variables.
Mar 21, 2013 | JVC HD-61Z575 61" Rear Projection...
Playstation lights turn on, But nothing apears on screen?..........
Did your previously had it hooked up through hdmi????? Are you getting sound????? Try with the standby light on pushing in the power button and holding it until you hear a beep or two then let go....wait a few 10-15 seconds and see what happens....
Mar 28, 2012 | Video Game Consoles & Games
Protection mode on my amp
YEA CHECK THE OHMS ON THE SUB TO MAKE SURE THEY MATCH UP TO THE AMP JUS SOUNDS LIKE THE WIRING IS OUT OF PHASE.
Jun 15, 2009 | Pioneer GM-7200M Car Audio Amplifier
The DVD an CD doesn't work
Check speaker connections and wires and make sure all wires are plugged properly. If problem still exist then unplug speaker one=by-one and test home theater to determine what speaker is causing Protect error.
May 17, 2009 | Sony DAV-C700 System
Protection light
take the amp out and hookit up to the car battery and let it charge then unplug it do this a couple of times then rehook it to the cars audio system it sounds like your amp may be locked..
also check your speaker wires from amp to speaker box then from the back of the box to the speaker inside the box you may have a short..
thats where i would start.. hope this helps
Dec 19, 2008 | Car Audio & Video
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
Red light
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Oct 02, 2007 | Power Acoustik LT-980/2 Car Audio...
Car Audio & Video Logo
285 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
hoyzee1
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
