Question about Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
We bought a new HDTV from Sanyo. The XBOX 360 is connected with the component cables, I hear the sound of the XBOX, I do not get "NO SIGNAL" from the TV, it is just black. when I put in a DVD the DVD will play. After watching the DVD, I press the button to get back to the Xbox picture it will show but as soon as I click go back to Dashbord, the screen gets black. Why?
What is wrong?
  • 2 more comments
  • patricia_217 Nov 15, 2008
    I figured it out. The setting on the XBOX for Display was set for the old TV to 1080p and the new tv didnt catch it. It is receiving at 1080i. I had to switch it the AV cable to TV and then go to settings and change it to 1080i and then switch the AV cable back to HDTV.
  • karenstew Dec 01, 2008
    I am trying to move my system from an HD TV to a TV that is not HD. I'm getting sound but no picture. I tried changing the HDTV settings in display to 1080i and it still didn't work on my non HD TV. Does anyone know what I can do? I guess it started when I moved my system from my TV to my parents HDTV.
  • trigga69 Feb 14, 2009
    was playing cod warfare online screen went green then purple,thought at first it could of been a connection problem,so logged out and switched off.Left it a coule of minutes turned it back on had green lights fan blowing everything as normal had sound but black/blank screen,checked leads checked tv connection all good but still no change ? any idea and can this be fixed ? thanks
  • deanzylad Apr 25, 2009
    my xbox 360 elite was working fine on a lcd tv nd then on the component screen one day it suddenly says no signal yet i cna still hear the backgroun noise form the xbox.......tried changing to different av components and changed to hdtv cable still no luck ... could it be that my cable connecting the xbox to the tv is faulty
    Problem Solver:
  • 5 Answers
Did you check to see if the av conponent was on tv/hdtv?
Posted on Nov 15, 2008
  • clayton fox
    clayton fox Nov 15, 2008
    or try holding y and right trigger when startiing it
  • clayton fox
    clayton fox Nov 17, 2008
    yup it some times help to read the oweners manual yaknow just so you
    dont have to go through all the trouble with going online and asking
    for help but what ever : D
2 Suggested Answers
  • 6784 Answers
SOURCE: xbox 360 hdtv connection help!!!
Yes, you will need HDTV compatible AV cables.
Posted on Jun 25, 2009
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
Nov 20, 2015 | Sanyo DS31590 31" TV
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
When I turn on my xbox 360 I get sound but only a
this seems like a component cable issue, are you connecting the system to an hdtv? if so check the component connections to make sure its connected to the proper ports.
May 21, 2010 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Sound with no picture
Have you looked at the side of the cable and made sure that the switch is set correctly? you have to select either HDTV of AV I believe. If that isn't the problem, try hooking it up through a different input on your television. I don't think it's your xbox because with any hardware failure, you would get the RRoD (red ring of death). I would definitely troubleshoot the TV. Try to hook up a regular DVD player in the input that your xbox is in and see if it works.
Jan 29, 2008 | Microsoft Xbox 360 Console
Emerson LCD HDTV 19 inch won't connect to Xbox 360
Im not an expert on the 360s, but I believe there is a switch or option on them to play them in HD feed. They must be set to play HD as far as I understand.
Dec 26, 2007 | Televison & Video
Microsoft Xbox 360 Console Logo
2,452 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
