Question about Samsung HCN653W 65" Rear Projection Television
No picture i have a sansung and it will not turn on. the timing light will bleank 9 times and then all power will shut down. their is no pictureand the power responds to the remoat. what is wrong?
Forwarded from someone named dillin Your TV has a short in the power supply, and or the sweep drive, sweep power supply,or the convergence module on this set will also kill the set from time to time. If you have a service manual, and a multimeter there with you and you know how to troubleshoot solidstate printed circuit board, the first thing to do would be to get a servoice manual, located the convergence module, disconnect all the plugs to the module. Next pull off all trhee picture tube sockets off the picture tubes and lay them aside, making sure they do not touch anything.. Plug in the set. If it comes on with sound, you most likley have a bad convergence module. Here are the spects and part numbers. Part Number: BP95-00415B, Description: ASSY SUB PCB-CG MOD, Stock Availability: Item usually ships in 5 business days, Price: $87.02. you get it here at http://www.samsungparts.com/,enter your model number If the set does not come on then your going to need to trouble shoot the sweep and main power supply's. I have had in this model the Hi voltage block cause this set to go bad once . If you have no electronic troubleshooting skills, Play it safe and call in a tech to assist you in this repair. Good Luck, and let know how you made out.
Posted on Mar 08, 2007
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Lamp or Power Supply (Ballast)?
Power Supply is the problems.The lamp problems you will not have picture at all.U said have power and picture all day sometimes right?Power supply board have intermitten problems.
Mar 04, 2010 | Panasonic PT-56LCZ70 56" HDTV
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
Tv doesn't want to start
The power light blinks about 9 times and the tv wont turn on what does this mean? its a magnavox 51mp392h/17
Aug 05, 2009 | Sony Televison & Video
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
SANSUNG HD TV
I have the HLM-5065W DLP TV. Replaced lamp 1 year ago. It attemps to start 3 times before shutting down. then all light are flashing. I hear an electrical sparking and I see the bulb flicker but that it. Did the bulb go out again? IF so why so soon. If not what is the problem??
Apr 17, 2008 | Samsung HLM5065W 50" Rear Projection...
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
No sound-power switch on T.V. flashing 9 times
May be a bad optoIC. Goto www.magnavoxhelp.com to see if they have a repair kit for your model.
Oct 05, 2006 | Philips Magnavox 51MP392H Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
