Question about Dryers
My 29" whirpool dryer is not putting out any heat. I have checked the lint vent outside and cleaned it( It was very dirty)and I checked my fuse box and it is still not putting out heat. Mod wed5540sq0 ser mt2713850. Any assistance would be great! Someone told me it might be the heater coil? How would I change that?
  • 5,911 Answers
The following link describes how to diagnose and repair a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If your dryer vent was clogged, chances are you have lint build up INSIDE the dryer as well. Read through the paragraph that discusses the proper ventilation for a dryer. I would recommend you open the dryer cabinet and clean it out thoroughly. Lint build around the heating element can smolder and is a fire hazard.
The most common failed component in a dryer that overheats is the thermal cut-out (TCO). If the TCO is bad, it is strongly recommended that you replace the Hi-Limit Thermostat with it. These components are usually sold as a set. Failure to replace both components can result in premature failure.
Make sure you follow the advice given and check and verify all possibilities to rule out multiple component problems. In addition, make sure you read the bottom section of the link, first and make sure your voltage at the wall receptacle is correct.
I hope this information helps you. Let me know if you require further assistance.
Posted on Nov 15, 2008
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Dryer venting
Click here to get some literature for your washer/dryer. Pick the exact model you have and check the pdf files.
Jul 10, 2008 | Whirlpool LTE5243D Top Load Stacked...
My estate dryer model #eed4400wqo
I suppose you want to clean the lint vent to outside. Clean out the filter first by removing the manual filter and pulling off all stuck lint. Try this link to clean the vent:
How to Clean Clothes Dryer Vent
Feb 12, 2015 | Estate Eed4400wq 29 6.5 cu. Ft. Electric...
I have a gas dryer that when cycle begins it heats but after a while it stops heating and it takes too long for clothes to dry...Why is this happening?
I would check the the vent hose first. It might be clogged with lint or stopped up some other way or even crimped where the air won't flow. Turn on the dryer and go outside and be sure there is a good flow of air coming out of the vent. If there's not much air flow dis connect the hose and clean it out
Dec 13, 2014 | Whirlpool WGD4800XQ Whirpool 29" Gas Dryer...
Clean the Lint Filter or Condenser
check inside it may have a lot of lint build up in it, check the vent to outside and be sure there is no sharp bend in vent pipe to make it over heat. the straighter the better !
May 09, 2012 | Dryers
My kenmore 110.74602300 does not dry as well low heat and then the heat goes away on any setting
Your dryer may have a failed heating element (if electric), or a dirty burner (if gas). Likely though, the ducting that connects the back of the dryer to the vent is probably partially clogged with lint causing the dryer to overheat and shut heat off. Check the outside vent for lint buildup, pull dryer out and check duct work, also check vent pipe on back of dryer for buildup.
Sep 15, 2009 | Kenmore Dryers
Turn on but no heat
A bad thermal fuse will keep the gas valves from opening , therefor , no heat at any time . There will be no orange glow with a bad ignitor (used to lite the burner ) . Bad coils , the ignitor will glow and when the sensor clicks to cut off the ignitor , the coils should open to let the gas thru . Your dryer has a little peep hole you can remove to see the operation of the gas valve . Also , check the thermal fuse again ( or put the 2 wires togather to check) , disconnect the vent hose from the dryer and dry a load to see if dryes correctly .( Make sure you have good air flow at the dryer )The reason for this is because a dirty or clogged vent , not cleaning the lint screen vent hose kinked , or vent clogged from dryer to outside , will cause the thermal fuse to open .
Jul 29, 2009 | Kenmore 74602 Gas Dryer
Dryer will not start
hi thanks for the question remove the venting to the outside clean all lint. remove the back panel on the left on the air duct you will see a small piece of plastic with 2 small blue wires to it thats a thermal fuse. replace it. dirty venting is sometimes the cause, of the failure. thanks the appliance doc
Jun 23, 2008 | Kenmore 74602 Gas Dryer
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
170 people viewed this question
Top Dryers Experts
