Question about Gateway Computers & Internet
Mouse turns off and I have to shut off computer
More and more the mouse on my computer will turn off and I have to restart my computer to make it work again because I lose all control of the unit. Is this a mouse problem or something worse?
  • bcrawford423 Nov 15, 2008
    Thanks for your answer. Please forgive me, but I am pretty much a computer illiterate. What's the difference between USB and PS2?
    President:
  • 1,901 Answers
Is this a cordless mouse? If so, have you replaced the batteries?
If not, is it a USB connection? If so, try another USB port.
If this is a PS2 connection, you may want to spring for a new one.
Posted on Nov 15, 2008
  • Wayne Mineard
    Wayne Mineard Nov 15, 2008
    USB is rectangular on the end that plugs into the computer. (The left side of this pic.)
    PS2 is a small round connector. (The right side of this pic.)
After restarting my computer the cursor stopped responding to the mouse.
You're probably running Windows, and that's a common problem, and usually very easy to fix. If you are using a wireless mouse, remove the USB receiver, wait 10 - 20 seconds and put it back in. If that doesn't work, remove USB rec. , shut off mouse and go through a restart. Try restarting with them removed, if it doesn't work, try restart with them in and turned on. You can use keyboard commands to do this next part If that doesn't work, go into the Control Panel, system, device manager, mouse, right click ( lined square to right of space bar ) then properties, reset to default - The windows symbol beside space bar is the start menu, the arrows control scrolling through options or moving the page, TAB changes what the computer is focused on, ALT and F4 closes whatever program you're focused on - pressing it twice will cause a restart. And if your comp ever jams up, press CTRL, ALT and DELETE at the same time, opens task manager and unjams,,, usually. Hope some of that helped. Grimm
May 01, 2015 | Computers & Internet
The mouse
Hello there.
I recommend doing the following:
1) Shut down the computer (you can hold down the power button on the front of the computer base unit or laptop power button for a few seconds instead of using the mouse)
2) Unplug the mouse base station.
3) Plug the mouse base station in again
4) Turn on the computer and let it start up as normal.
5) Watch for any system messages appearing, like found new hardware.
These steps will verify that there is not a problem with the mouse's base station plugged into the computer. Another thing to check is if the mouse requires batteries, this is often overlooked.
If after doing this there is still no pointer registered, i would suggest trying the mouse in another computer, and if possible trying a different mouse on the same computer.
If the mouse works on another computer then it could be a software problem, which we can help you with.
If the mouse doesn't work on another computer, but a different mouse works fine on the same computer, then im afraid your mouse has to be replaced.
Please post back after trying the above steps and let us know. Telling us which mouse you have exactly will futher help.
Hope this helps.
May 09, 2008 | Logitech Cordless Mouse
Unifying receiver not recognizing M505 Wireless Mouse
You mentioned about using the mouse in your friend's computer but you didn't mention if it worked or not. Did it work?
You also mentioned that your friend has the same model which works perfect with his computer. Did you try his mouse in your computer? Did it work?
If his mouse works just fine in your computer then you would need to replace your mouse because it's defective.
Apr 23, 2013 | Logitech M505 Wireless Mouse Red
The scroller on the top of the mouse does not scroll the page
Go to your control panel of the computer. Click on the tab "Change mouse whell settings" If you do nto find such tab then search for that tab by puttin word "mouse" in the search box.
There you can change scrolling setting. If it doesn't work then remove the wire of your mouse, shut down computer.
Insert the wire and restart computer. This will surely work. If not then contact I'll give you other remedy.
Sep 22, 2012 | HP Wireless Optical Mouse
My DEll mouse stops working when it feel like it. have to shut computer off and turn back on for mouse to light and work for awhile again. What"s wrong?wrong
Try your mouse in different USB ports, if it works well in the other ports then you know your original port is bad. If the mouse still acts up, then go ahead and try another usb mouse in the computer. If the 2nd mouse is working then you know the original mouse is bad. If the 2nd mouse is not working then you know that the usb ports on your motherboard are bad.
May 17, 2010 | Dell U0636 Mouse
Does the labtec wireless mouse turn itself off when not in use
You should always safely shut down and turn off your computer before plugging or unplugging the mouse from the PS/2 mouse port. If you do not safely turn off your computer, you may damage the mouse port, the mouse, or both.
Your Labtec mouse should detect and function by simply connecting it to the computer´s PS/2 mouse port or USB port. If you have 3 Button Labtec Mouse (M/N: M-CAC64), your mouse will work in the PS/2 and serial port with the supplied adaptor. If you are using the 3 Button Labtec mouse, we recommend using the PS/2 port. To determine the model number of your device, turn it upside down and look at the label. Model numbers are indicated by "M/N:". This will help you determine what system ports your Labtec mouse can be connected to.
Thank you
Mar 14, 2010 | Labtec Wireless Desktop Keyboard/Mouse...
Computer won't recognize mouse now......
I'm going to assume that your mouse has a USB connection, it may have a stuck flag in the registry. Each time you shut down your computer, the flags should close, when you restart, each device is reinstalled. If you have a stuck flag Windows will think the device is already installed.
If that is the case, shut down and remove the USB mouse. Hook up a PS2 mouse, restart, go into the regestry and remove all the USB mice listed under USB mouse. Save the changes, restart, then remove the PS2 mouse and plug your USB mouse in. Windows should detect new hardware and reinstall it.
Jan 05, 2010 | Logitech Cordless Click! Mouse
Microsoft Wireless Mobile Mouse 3000 shuts down my computer
This is the sign that mouse if faulty because if the laptop detects a threat from the USB ports, usually power related, to protect the parts, it turs off.
Advise to change the mouse...
Mar 11, 2009 | Microsoft Wireless Mobile Mouse 3000
Old Computer 1999-2000
well, check your BIOS..disable your virus scan then save the settings then restart your computer.
Jan 24, 2008 | Warrior 797146022002
Computers & Internet Logo
424 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
