Question about Magellan RoadMate 700 GPS Receiver
Long warm up time
I did not have this problem for many years. Now it takes 45 minutes to warm up. The 700 temperature is about 70 Fh. How can I fix it?
  • ok56 Nov 21, 2008
    THE WARM UP TIME OF MY ROADMESTER 700 IS ABOUT 45 MINUTES. aMBIENT TEMPERETURE IS ABOUT 70Fh. NOBODY COULD FIND OUT THE SOLUTION SO FAR.
    Sergeant:
    Champion:
  • 347 Answers
Look what i found looking in our files:
http://www.fixya.com/support/t144530-message_tempature_low
I hope it can help you out with your problem.
If not, let me know.
Good luck,
Dahaka
Posted on Nov 21, 2008
    Brigadier General:
  • 6,966 Answers
Offhand, if reset or software would not address the issue. Might it be a hardware problem. If everything else works except the "warm up time", then it is probably the sensor the detects internal temp. Assuming that it is no longer under warranty, then perhaps one can venture a DIY (do-it-yourself). To open, remove the 4 screws and unsnap the lock/clip on the end.. This page for another unit/model might give you insights. The temperature sensor is located on the LCD assembly. incidentally, it has been noted that some cable connections do get loose specially on the hard drive. Pls check all connectors.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 23, 2008
    Hi again,
    Any updates or developments so far?
  • 104 Answers
Have you tried to go the the Magellan site and download the latest software update (they call is "patch") for your unit?
Posted on Nov 15, 2008
  • 4,806 Answers
Download an install the latest firmware to sort the problem, you may need to uptade it afterwards
    Genius:
  • 1,269 Answers
Initially, try to reset the unit. Remove the battery for about 10 mins. Software/Firmware update can fix the problem. Go to the manufacturer's website and download the latest update.
Scotsman cme306
Here video. Was long freeze error. found out that it was bad ice thickness probe. Hope this helps to someone
May 21, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
When the motor is cold and the outside temperature is below 70 the car will not stay running. Will die with in 30 seconds or so of starting, then you have to wait a minute or two befor the car will start...
Are there any service engine soon lights on associated with this problem?
Possible CTS (Coolant Temperature Sensor) or another sensor giving faulty data for the cool air temperature.
Check spark and gas delivery when cool, below 70 deg. If the spark is not being delivered or the fuel injectors are not delivering fuel at this temperature, it will explain why it doesn't run right until it is warmed up.
Oct 08, 2010 | 2001 Ford Windstar
Water changes from hot to cold. Valves checked out
Bad thermistor or bad board. Or its just a energy super saver and it will not let you use all that hot water. Did it work before or its been like this since new? New energy star models will only let it just get warm for hot wash, saving energy. warm wash is like 70 deg water.
Nov 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Worst refrigerator I've ever owned!
Your probablem is either your defrost timer and/or your Defrost thermostadt. Your defrost heaters are staying on too long and these two items control that.Once the defrost time turns on your heaters the Thermostadt will turn them of at between 55 and 70 degress then the fridge sets for 20 more minutes to start up again but the heaters will be off.
Sep 22, 2009 | GE PSC25MSS Stainless Steel Side by Side...
My Mgellan 700 was working fine for many years.
ok56,
Thanks for using Fixya 1st of all.
This problem has surfaced MANY times. It has been solved by numerous solutions. Without replacing the circuit board behind the keypad or the LCD I do NOT know a way to solve this. There never was a definite solution that remedies this. Possibly unplugging/replugging the ribbon cable from the LCD. Sorry I couldn't be of more assistance. Let me know if anything changes.
-Daniel
Nov 15, 2008 | Magellan RoadMate 700 GPS Receiver
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
LG Dehumidifier Not Working
the freon has leaked out, must be replaced.
Jun 05, 2007 | LG LD65EL Dehumidifier
Temperature below safe level
I've fixed that error by swapping out the PCB board (or the keypad board). Which you can't very easily do that.. unless of course you have a boneyard of these lying around. Additionally, it could be the Hard Drive, this error hasn't been narrowed down to any one specific cause to my knowledge. I'll take it off your hands if your going to buy another one though. Respectfully, -Dan
Oct 24, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
29 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
