On my gateway laptop screen it shows things double and not clear or brigt now
  • 4,806 Answers
Reinstall the graphics drivers through device manager
Posted on Nov 15, 2008
Gateway Laptop with windows 8. Mouse pointer gone and won't come back
See if the mouse pad has been accidentally turned off. This can be done via the "Function" button on your Gateway laptop. To enable your mouse clicker again on your Gateway, head on over to the "Control Menu" in Windows and double-click on the "Control Panel" icon. Click on the "Mouse" option under the "Printers and Other Hardwareicon1.png" tab. In the next menu that pops up, click on the tab listed as "Device Settings." From this menu, you should be able to locate a listing for the mouse pad on your Gateway laptop. Click on this listing. From here, you should be able to enable the mouse again. Click "OK."
  • Head over to the official Gateway site online (see Resources). The above enabling of the mouse device under "Device Settings" may not have worked. Make your way to the "Software and Drivers" area of the site.
  • Check over your Gateway manual and find your specific serial number for your machine. Enter the number into the Gateway site when prompted and check to see if any driver updates exist for your mouse on your machine. If so, click to download the update, and then double-click the file on your computericon1.png to install it. Restart your Gateway laptop to have the changes take place. Your mouse should now work.
  • Jan 26, 2013 | Gateway Ne56r34u 15.6inch Laptop Black
    When I connect the lcd to my laptop, the lad shows
    hi atuire,
    try hooking up the lcd screen toanother computer and if it shows the same double screen again then there is aomething wrong with your lcd monitor,
    you may want to use another monitor with your laptop to ensure the problem is not on the laptop's side.
    if issue stays same with another monitor, then just right-click onto desktop background, goto properties and have a look whether you have enabled the shared monitor feature
    (meaning that u can use two screens with just one graphics card parallel, to work on a 'wider' range of sight.
    Therefore your machine's graphics card sually must be equipped with both: a standard vga out and a HDMI-out as well.)
    if your machine ddoes not have these capabilities but still the monitor sharing is turned on from the software side, this might cause the problem. To disable simply change the graphics card's
    propertiers as descried above.
    Good luck
    Sep 06, 2009 | Gateway Computers & Internet
    Screen stays black when booting up on Gateway laptop
    there is a inverter in lcd that makes shinely, white .
    it looks like inverter issue. need to get service.
    May 29, 2009 | Acer Aspire One PC Notebook
    Gateway model # CX 2618
    First test if it works on an external monitor. If it does you will need to clear the CMOS. To clear it:
    remove the battery, unplug the cord, and hold the ON button down for 30-60 seconds. Then turn it on. Thats how you clear it on most laptops.
    If it does not work on the external monitor, you probally have a bad video card and need to replace the old one
    May 26, 2009 | Gateway CX2618 Notebook
    Laptop screen goes white
    hi..right click on desktop,choose properties,select
    settings tab and then choose highest bit in color quality.
    see if it does make any difference,sometimes having low
    or medium bit color quality can do such thing.
    check it out..
    thank u..
    rate me..
    May 04, 2009 | Fujitsu Siemens Computers & Internet
    Memory Problems for a Gateway Mx3215 Laptop
    There are two different memory modules for that series.You can determine which you need by the chipset for you machine.If you have a Via VN800 Chipset You need the 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v. If you have the NVIDIA nForce 410 Chipset The you need the 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v Hope this clears up your problem
    Sep 29, 2007 | Gateway MX3215 Notebook
    Computers & Internet Logo
    David Payne
    David Payne
