Question about E-Machines T1842 PC Desktop
Can not get T1842 to start up. Hit start button no response.
Have power. Have not used computer in quite a while. Tried to use tonight and would not start.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    more information please
    Scholar:
  • 172 Answers
Motherboard failure, contact me for support, easy to replace
chris
Posted on Nov 15, 2008
Mac power light flashes 3 times, no usb response
Push the power button and wait for 10 seconds.
Jan 24, 2018 | Apple Computers & Internet
Emachine t1842 will not come on. used to come on and brought up bios setup. i replaced battery, still same prob. then one day it would not turn on at all and has not come back on since.
I've had quite a few of these in my shop, and the problem is usually the power supply. Additionally, when the power supply goes out, it can do damage to the motherboard as well. First try swapping out the power supply and if that doesn't fix it, you will probably need a new motherboard.
Sep 08, 2010 | E-Machines T1842 PC Desktop
Power button has no response, no lights..nothing
E-machines are notorious for this type of issue. You will need to contact E-Machines and check to see if you have warranty. If not you will want to talk to them about your options.
Jul 15, 2009 | Intel D845GVSR Motherboard
No power when i push power button
clash pin on motherboard power pin or clash bios jumper
Jul 13, 2009 | E-Machines T1842 PC Desktop
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
All lights flashing - machine won't start
you should be able to locate the tech sheet by gaining access the control panel , this sheet contains the info your looking for.
Phil
Jun 10, 2009 | Washing Machines
Macbook wont start
hi bobbie,
The only reason to pull the battery is to reset the SMU (used to be called the PMU). Do this when it's unplugged and completely un-powered, hold down the Start button for at least 5-7 seconds (count slowly) and then re-energize (battery and AC usually).
Also try zapping the PRAM (restart, holding down Command/Apple, Alt/Option, "P" + "R" (all four at once) and repeat until you hear start-up chimes at least 3 times. These may not fix it, but won't hurt.
The flashing question mark indicates that it's not finding the OS on the hard drive. In my experience, this usually means a re-install of the OS. If it's still doing this after the first two step above, dig out your install DVDs and get started.
Starting with the alt (option) button should put you into the Boot Manager. The password should typically be the the password for your (hopefully Admin-enabled) user account. Did you set the Master Password in the System Preferences? If so, you're back to erasing/starting over. If you use powerful features like this, select passwords you can remember, or write them down and store them securely (NOT a Post-It™ taped to the bottom of the MacBook or penciled in on the bezel - yes, I've seen both).
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Mar 27, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
EMACHINE T1842
I had the same issue. I know the problem. Your power source is not working proprietly and you need to change it.
Dec 24, 2008 | E-Machines T1842 PC Desktop
I have no power. although when i plug it in after sitting awhile the green light comes on the back saying there is power and as soon as you hit the power button all fans make half a turn and the green...
The problem here is the POwer SUpply Unit of your computer the opne that is responsible in giving power to your computer since its already 6 years the power supply gone bad already and needs a replacement, so what you need to do here is to buy a new Power Supply and repalce it already so you can use the computer again...
Don't forget to rate the solution FIXYA thank you.......
Oct 16, 2008 | Computers & Internet
E-Machines T1842 PC Desktop Logo
99 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
