Question about Harman Kardon FL8350 5-Disc CD Changer
HD FL 8350 disc tray will not open. Flashes disc error
My HD FL 8350 5 disc changer flashes error when I try to open the disc tray. After several tries, sometimes it opens but most of the the time, it does not. Help!
3 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: HK FL8380
Agrassmyer
Happy Holidays!
Well, difficult problem here, you has to open the cover to remove manually on the changer de CD, other than that, prove leaving the on botton pressed when connected, and see if open,
Posted on Dec 30, 2007
skywavebe
  • 1267 Answers
SOURCE: FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Posted on Dec 27, 2012
Yes when I try to open the Xbox 360 disc tray the power button in the center flashes as if the disc tray is opening, but doesnt open. it flashes even when i havnt pressed a button for it to open the d
Try turning off the 360 then turning the xbox on its side, turn the machine back on holding the eject button and the power button together for about 30 secs then the machine should function normally
Jun 19, 2014 | Microsoft Xbox 360 Console
416b-4174-b680-0f00-c000-0034
I had this error code as well. Here's the solution that ended up working for me:
  1. Eject the disc tray and remove any disc from the console.
  2. Important: Do not close the disc tray. Leave it open.
  3. With the disc tray open, remove the power cord from the back of the console.
  4. Gently push the disc tray about half-way back into the console.
  5. Plug the power cord back into the console.
  6. Push the power button on the console. The tray should close the rest of the way, then the console should restart and display the Xbox Dashboard.
  7. Important Do not use the controller or the disc eject button to turn on the console.
  8. Try updating your console software again.
What this does is put the DVD drive into Mode-B, which is an alternate operating state that allows the drive's physical memory banks to be flashed with new firmware. Because the latest XBL update involves flashing the drive with new firmware, you may need to physically put the drive in Mode-B. The latest update flashes the drive to make it compatible with Microsoft's new high-capacity disc format, XGD3, which will be used sometime in the future.
Jun 10, 2014 | Microsoft Xbox 360 Console
My hk 30 player tray flashes (disc error) with every digital audio disc. help
Often times the tray and pickup lift assembly are related and there is a cam alignment. IF you pulled out with force the tray the alignment may have been upset to where the cam is not completing the lift of the Pickup and if not in the right position the laser will not be able to focus. The correct solution is at a Technicians bench where a new belt could be put in, lubrication that is required and some cleaning will be done.
Jan 21, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
Dec 24, 2010 | Pioneer PD-F407 25-Disc CD Changer
Everytime I try to open the disc tray it flashes either EX-Change or mechanical error and won't open
I have a Sony MHC-GX555 stereo and every time I try to open the disc tray it either flashes EX-Change or mechanical error and it won't open.
May 24, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Disc error
hi, does it take the tray out or stop half way?
the alpine changer mechs have a problem with jamming up.
this also covers the mercedes and BMW models too.
if its just tray 3 thats not working then it could be the tray try swapping the tray around this will rule out the mag/cart/tray. that way we can tell if its the changer or the mag/cart.
if its all trays that it dont work on the try tapping the mag with the handle of a screw driver while its trying to load, this is normally enouight to unjam the loading arm..
Mark
Blue ICE
Feb 24, 2008 | Alpine CHA-1214 12-Disc CD Changer
HK FL8380
Agrassmyer
Happy Holidays!
Dec 29, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Harman Kardon FL8350 5-Disc CD Changer Logo
52 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
