Will the shifter cable from a 1995 geo metro work in the 1996 model
SOURCE: repair speedometer of 1996 Geo Metro
You can check this link it will help you to inspect and replace the speedometer cable http://www.autozone.com/az/cds/en_us/0900823d/80/04/b8/4f/0900823d8004b84f/repairInfoPages.htm
Hope that helps.......
SOURCE: how to change water pump in 1996 geo metro?
DITTO ON AUTO ZONE...Don't buy a book, have Auto Zone people copy instructions from their data base for free.
SOURCE: four wheel drive will not work on 1995 geo tracker
You need to take the cover off your hub and clean and grease the lock ring. It is attached to the spring. It sounds as though your hub is rusted open.
SOURCE: How do you fix a sagging headliner in a 1995 Geo
These headliners are glued to the inside of the roof. There are four huge ribbons of hard glue down almost the full length. It will tear off part of the headliner like opening a carboard box (because it is cardboard). You have to try not to bend up the headliner getting it off. The edges are glued under the door seals. Typically the seals aren't glued though, they just pull down. Those plastic plugs need more of an even pressure to pull out without damage; you might be better off with some school scissors rather than a single screwdriver, or you may find a tool at the partshouse for $5 or less. You can find plugs like that at Lowes if they're damaged, but typically just black or white only. Really you might want to shop around first. Someone around here used to advertise $50. That would be well worth skipping this kind of wrinkled, gluey hell.
SOURCE: Hello, my 1995 geo metro back doors won't open,
Won't open with the outside or inside handles? Like the lock is stuck or like the handles are broke? Do you know if the vehicle has child safety locks?
el geo usa fichas o busos
