Question about Eureka Vacuums
Fix a skrew thread which is thread into plactic
Thanks for getting back, but my dad fixed it, all he really used was a little super glue to hold the skrew in, not really a total fix but it works. thanks though.
Posted on Nov 21, 2008
How do i fix my tension,bunches up the thread
sounds like a blunt needle,or tension at wrong setting.replace needle first.adrian,,,,
Feb 12, 2015 | Singer 8763 Curvy Computerized Sewing...
Replacing belts
there is two of them, one for each side, two screws hold on a clear plastic cover on both sides, the belts are serpentine, one on the plactic gear, one on the metal drivegear, see shiny parts where the belts have been traveling, good luck, pretty easy
Aug 15, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Electrolux ZUA3820P vacuum cleaner - how to access motor for repair
Tricky but you need to lift the slider cover off that adjust Min & Max speed and you will find 2 screws underneath, then you need to slowly take of plactic cover around the inlet hose and you will find another 2 screws
Apr 11, 2012 | Electrolux Vacuums
I have just accuired a Pro Sew MK-C111-3 i can pick the thread up from the bobbin but when i start to sew the cotton breaks every time, i do not have the manual so i am unsure if this is a tension thing or...
Hi, I have aquired a PROSEW Mk3300-1 and need a manual or instructions of some sort how to use, thread, oil etc. can anyone point me in the right direction please.
fillamore@btinternet.com
Sep 21, 2011 | Vacuums
Mmy bobbin case fell out of the casing spot and then the bobbin fell out. I don\t have a manual, used to know how to fix the problem simply but have forgotten. thanks for your help.
Hi. Find the end of the thread and pull it out, off of the bobbin a couple of inches. Hold the bobbin with the thread coming off of the top so that if you rotated the bobbin counter clockwise it would wind the thread onto the bobbin. Now take the bobbin case in your left hand with the stem in the center of the case facing toward you. Stick the bobbin into the bobbin case and, taking the end of the thread, pull it to your left while pushing back on it somewhat until the thread enters the slot in the bobbin case. Pull the thread so that it slips under the thread tension spring, pull a little more out, then reinsert the bobbin case until it is seated all the way in the hook. It will probably have a catch that snaps in place.
Aug 20, 2011 | Vacuums
I have needles snapping and bobbin tangle
Try to repair in this order.
1) Your machine likely needs oil. Especially put a few drops of oil on the outside edge of your bobbin holder.
2) Try replacing your needle if you have some spares. If you are using a decorative thread (metalized) use a needle with a teflon lining on the eye (called metallic thread needle).
3) Try buying a better quality thread. Do not use generic thread in a sewing machine (i.e. "made in cheap country" with no brand name)
Please rate me..
May 04, 2011 | Vacuums
Lux 5000 put in new bag but when i turn on the
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Oct 25, 2009 | Electrolux Lux 5500 Canister Vacuum
Have the cannister 6500 SP just changed all filters but when I start the vaccum it shuts itself back off and the full bag indicator light comes on?
Jun 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
The hose is disconnected, new bag in unit, new filter, unit runs when hose is detached but immediately turns off when hose is attached but hose has no obstruction, etc.. i was told i need some sort of...
There is a vacuum hose that attaches inside the unit to a round clear plactic piece. In most cases you can simply cut the small vacuum hose and it will fix the problem.
Apr 16, 2009 | Electrolux Epic 3500 Vacuum
Vacuums Logo
80 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
