Question about Lexmark Office Equipment & Supplies
Change cartridge on Lexmark 1200 - Lexmark Office Equipment & Supplies
  • 101 Answers
Cartridge changing is documented in the user guide, you can download and open the user guide on your compter from this page
http://www.lexmark.com/publications/eng/1200/index.html
if you are unable to open the manual you are most likely missing the document reader you can get that from this link
http://mirrors.foxitsoftware.com/pub/foxit/reader/desktop/win/2.x/2.3/enu/FoxitReader233_enu.msi
Posted on Nov 15, 2008
  • Is there a problem, why have you rated this Thanks for trying? Can I help you?
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
First time using, says error #1200
The 1200 error indicates that either the cartridge/s is not properly installed or snapped in the cartridge carrier, the encoder strip (transparent strip behind the cartridge carrier) is out of place or something is blocking the cartridge carrier's path. This article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One will help you identify and resolve the issue.
May 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
Eroor 1200 is showing
May 30, 2011 | Lexmark X4270 All-In-One InkJet Printer
Error 1200 is showing
The 1200 error could be caused by a cartridge not properly inserted in the carrier, encoder strip got unseated from its position or there's something blocking the cartridge carrier path. Try to refer to this article in the Lexmark website to determine what's causing this and resolve the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
May 19, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have done solution 1 to get cartrage moving, but printer still error # 1200,what else can i try?
The "1200" error message can be caused either by the cartridges that are not snapped in correctly, the encoder strip (transparent strip) is not in its position or something is blocking the cartridge carrier path. Please refer to this article in the Lexmark website on 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
Feb 24, 2011 | Lexmark X4250 All-In-One InkJet Printer
We are not able to send faxes,the error message is 1200. The reference number for the fax is x4270.
The 1200 error indicates the cartridge carrier has stalled. It could be caused by a cartridge that's not properly seated or the encoder strip (transparent strip behind the cartridge carrier) is out of place. Refer to this article from the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One to help you identify and resolve the problem.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Where are print cartridges located in the Lexmark 1200 series so that I can change cartridge? Got printer at a sale and don't have manual.
I have a Lexmark X1270 and this is probably the same as yours.Lift the top (not scanner lid!) and with power on the cartridge containers will locate centrally for you to access,once located these coloured containers have a hinged lid,pull the lid upward to remove cartridges contained within.Hope this helps.
May 11, 2009 | Lexmark X1270 All-In-One InkJet Printer
PRINTER
The following link provides the user guide and setup sheet for your printer. They explain how to change the ink cartridges.
Dec 25, 2007 | Lexmark X1270 All-In-One InkJet Printer
188 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
