Question about Pioneer SD-643HD5 64" Rear Projection Television
Blows fuse 303
Have same problem whats the fix.
  • 27 Answers
Tv's really dont Blow fuse's unless you have an electrical charge overload.
1 Transformer 1 capasitor 3 resisters from the color cannons arcing to gether...ok 355.00 to fix or so
Posted on Nov 21, 2008
I have a 2000 Buick century custom and I had drained my reservoir. Now everything I attempt to start my car my pcm fuse blows instantly. I've replaced my ignition switch and fixed my ignition column yet...
pcm fuse blows instantly ???? What number fuse , how many amps ? Where is it located ? under hood fuse box . ECM fuse 10amp ,underhood fuse box ???? When does the fuse blow ? when you turn the key to the start position . How about when you turn it to just on position ? Replacing the ignition switch an the column ????? Why did you replace these ? You think it was going to fix the problem ? or someother problem ? Bad computer maybe .
Sep 16, 2017 | Buick Cars & Trucks
How do i go about fixing this problem
Hi - when posting questions, please start with the year, make and model and how many miles are on the vehicle. Some codes are universal while others are specific. Then folks are more likely to be able to answer questions.
Dec 02, 2016 | Cars & Trucks
2002 Ford Mustang GT. I was driving and it made a bang noise and now I hear exhaust or air. check engine light is flashing codes P1131, P0303 and P1151. has anyone else had this problem
Did it blow the spark plug out of cylinder 3 ?
Code 303 is for a loss of power from cylinder 3, code 1131 is for a problem with the O2 sensor in bank one and code 1151 is for the same problem in bank two. Codes 1131 and 1151 could be caused by the problem source for code 303.
Sep 03, 2015 | Ford Cars & Trucks
What is the fuel issue?
Under hood fuse/relay panels on these are bad for water., when it is a hard rain. If 303 is the fuel relay, it wasn't fixed. I have tore panels like these apart to see what was wrong. And they are a mess. Copper wires get hot and bend, shorting out all kinds or fuses and relays. I just replace them now. And cover them. All I can figure is water pours threw them on hard rains. Even when the vehicle is sitting. Repaired many of them.
Aug 07, 2015 | 2003 Ford Expedition
Have 2005 f-150 5.4l. Reading codes p0203 and p0303. What is it and how hard to fix
Well code 203 is a problem with the injector circuit for cylinder 3, and code 303 is saying cylinder 3 is not producing power.
So the cause of 203 could also cause 303.
I would check the injector and the circuit first.
Sep 25, 2013 | Cars & Trucks
Lens error 303- I turn on my camera and it says lens error 303 and then shuts off. I don't know what happened.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 18, 2010 | Kodak EasyShare C160 Digital Camera
Tv only stays in standby mode
Replace Fuses 302 5amp and 303 5 amp Resolder all poor connection on power supply board and Replace Both STK ICs they are big black ics STK392-180s is best ICs Call Mats 1-800-628-1118 This should have you back to watching TV again.
Sep 19, 2009 | Pioneer SD-643HD5 64" Rear Projection...
How do i put a coil in a 2001 jaguar s type
303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual DESCRIPTION AND OPERATION Engine Ignition The electronic ignition (EI) system is a coil-on-plug (COP) ignition system.
SECTION 303-07B: Engine Ignition — 3.9L 2001 Lincoln LS Workshop Manual
v-8
REMOVAL AND INSTALLATION Ignition Coil Removal
  1. Remove the air cleaner outlet tube. For additional information, refer to Section 303-12 .
  1. Remove the bolts and the ignition coil cover.
  1. Disconnect the electrical connector from each ignition coil.
  1. Remove the ignition coils.
    1. Remove the bolts.
v-6
SECTION 303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual
  1. Remove the engine appearance cover.
  1. To access the RH bank ignition coils, remove the upper intake manifold. For additional information, refer to Section 303-01A .
  1. Disconnect the electrical connector from the ignition coils.
please rate as fixed if this helps.
Apr 28, 2009 | 2001 Jaguar S-Type
Pioneer SD-643HD5 64" Rear Projection Television Logo
70 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
