Question about Sewing Machines
Cant find a manual or thread machine properly.
Machine was threaded when purchased second hand and worked ok. one of the threads broke and I had to rethread and followed the map on machine. not stitching and threads breaking. Thread on right side needle keeps coming out. Also would like to find a manual to get tensions correct - mostly sewing stretch fabrics
  • Anonymous May 12, 2009
    the thread on the needle keeps breaking intermittently while stitching. How do I fix the problem myself?
  • 19,396 Answers
Submit a new question providing details on manufacturer and exact model, click here to submit a new query.
Posted on Nov 16, 2008
2 Suggested Answers
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
I was sewing with my Brother and it got stuck- whenever I tried to sew, a whole bunch of bobbin thread made a mess underneath the material and pulled until the bobbin thread broke.
Make sure you have cleaned out all the thread pieces in the bobbin area and it is clean.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point and test your machine. Adjust the top tension until both threads meet in the middle of the fabric.
Jan 28, 2018 | Brother Sewing Machines
My Brother HE 1 will not feed the top thread. When I embroider, the thread never comes off of the spool. I have rethreaded the needle, it is correctly threaded.
I don't have this particular machine, but have you made sure that you are threading correctly? I would completely remove your upper thread and put on a fresh needle. Also, whenever you do make a thread change, be sure and cut the thread at the spool on top and then pull the thread from the bottom (needle area) This will help prevent any fraying in the thread path that you can't get too easily. If this isn't an embroidery only one, try just sewing first so you will know if it feeds. It it does work in sewing mode, some machines are picky about thread. Here is a link for the path: http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_he1eus&ftype3=2076&faqid=faqh00000007_000
May 17, 2017 | Brother Sewing Machines
My mb4 is stitching designs off centered and when i started the machine it hit the hoop and broke the needle. i replaced the needle but now the thread keeps breaking?
Remove the thread and rethread. Usually, thread breakage occurs when the thread is not following the thread path. However, there could be other reasons:
Sewing Machine Problem 1 Thread Breakage
Nov 14, 2016 | Sewing Machines
Thread keeps coming out of the right hand side needle as I am over-locking. Could you advise what the problem could be? Thanks
May be threaded incorrectly or not seated in the tension disk.
Best course is to remove all the thread from the machine.
RAISE the presser foot and rethread from the beginning making sure each thread is threaded in proper order and that each thread sequence follows the manual.
When threading each tension disk, grasp the thread between the thread tree and the tension disk with one hand and with the other hand grasp the thread below the tension disk and give it a little tug to make sure it seats properly.
Be sure to pull the thread tails under the presser foot and toward the back of the machine before beginning to stitch.
Feb 22, 2016 | Sewing Machines
It was working fine then I broke a tread re threaded not wont sew but wwill cut
Remove the thread completely and rethread the machine from the beginning. Be sure to RAISE the presser foot BEFORE threading the upper thread.
Jan 10, 2016 | Sewing Machines
I broke a needle and tried to replace both needles. Now I can't get my machine to chain. I have rethreaded it, and replaced the needles, closely following the manual and threading guide but still
it's possible that when the needle broke it could have caused the
machine to jump time and would need to be serviced to see if it
needs adjustment.
Mar 08, 2013 | Sewing Machines
The bottom thread is all tangled. I have
Hi! This is the machine I use (mostly) and I've found it really doesn't like lint. I brush out lint every few hours and it has made a huge difference in how my machine sews. I suspect your machine may be as sensitive to lint as my is, so give her a really good cleaning. Then, rethread (yes, I know you've done that already, but do it again, for grins.) everything. Pay careful attention to the way the bobbin thread comes off the bobbin (from left to right) when you rethread. If you usually use the automatic bobbin pickup, don't. Pick up the bobbin thread the regular way, and, holding the top thread and bobbin thread securely in your left hand, start to sew.
I sure hope this helps!
Please let me know if this works, ok?
Robbie
Jan 28, 2010 | Brother CS-8060 Computerized Sewing...
How do I thread the Juki MO-644D?
Email me at sewingnz@gmail.com should be able to help.
Jan 19, 2010 | Juki MO-644D Mechanical Sewing Machine
Lower loop broke- do I have to start from step one?
yes, take all threads out, and re=thread according to the diagram, following the threading order.
Mar 02, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
90 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
