Question about Dell (E210882) Motherboard
Can't get past the system password prompt
When I boot up the pc, I get "Type the system password and press " then the prompt. I try rebooting and pressing F2 and F12 but it doesn't go to set-up or boot menu. I have recovery discs but they won't boot up either.
  • Anonymous Dec 12, 2008
    same for me
  • Anonymous Mar 28, 2009
    set system password, but when I try to type it in, it acts like my keyboard isn't even hooked up. However, when I press "enter", it says that it was a failed attempt and the system must shut down.
  • Dell Master
  • 4,806 Answers
You have to reset the cmos, take the battery out for 5 minutes without any power suppy attached, this should clear and bios passwords, then put the battery back in, you will have to set the date and time again
Posted on Nov 15, 2008
  • 101 Answers
The startup password is enabled... To get rid of the password prompt you will need to open the case of the computer, unplug all cables from the back, noting from the inside. On the inside remove the memory battery the bios should eventually clear and the password will be gone. There should also be a jumper you can change to another position and back to reset the bios, its documented in the user manual of the motherboard incase you have it.
remove the battery for 30minutes see if its solved if not leave it out over night, if its still not solved we will need to find the user manual to find the jumper, if you post the model details that are written into the motherboard I can look it up for you.
Anything Else?
  • daviespatric
    daviespatric Sep 13, 2012
    Thank you for the help, i have try to removed the cmos battery for 30 min, didn't work, overnight didn't work, The info on the monther board is ( COMPAQ 2001-2002 PROCESSOR BOARD). Please doa sk me any further question the will enable you to help me solve the problem. thanks
Fujitsu siemens lifebook a1220 master bios password
1. Exit Windows or reboot to the native MS-DOS mode,
2. Using the "Command prompt only" option from the Windows Startup Menu (hold Shift and F5 at the same time while your PC boots).
a) At the C:\> prompt, type: DEBUG
b) Press <ENTER>.
c) You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
(which will show as -o 70 2e at the DEBUG prompt).
d) Press <ENTER> and then type:
o 71 ff
e) Press <ENTER> and finally type:
Q
f) Press <ENTER> one last time, to quit DEBUG, back to the C:\> prompt.
3. Now you're ready to reboot your PC
a) Press the appropriate key or key combo (look it up in your motherboard manual if you don't know it) to access your BIOS Setup.
b) You'll notice that the password is gone. :)"
Feb 13, 2014 | Fujitsu Siemens AMILO Pro V2000 Notebook
Pelco dx7000 password
To reset the password for the DX7000 follow these steps: Reboot the system During the boot process, before "Starting Windows" message comes up, press the F8 key repeatedly to enter Safe Mode When the boot options menu comes up, select boot to command prompt only If you get the scan disk screen, you've gone too far and have to reboot. At the command prompt "C:\>" type cd windows and press enter. At the prompt C:\WINDOWS>" type edit system.ini and press enter. When the edit screen opens up, scroll down to the line beginning with the word "shell" Insert a semicolon (;) before the word shell = ;shell Save the file, exit, then reboot the system (You may have to hit ALT on the keyboard to get the File menu to come up) Press ALT+F followed by X and select Yes to the save and exit prompt Press CTRL+ALT+DEL to reboot. The system should now boot to a regular desktop, edit the system registry: Click on the Start button Select Run In the Open field, type in REGEDIT, then click on OK Find the password entry and delete the password: Double click on HKEY_CURRENT_USER Double click on SOFTWARE Double click CyberNetic Double click DVR Double click 1.0 On the right-hand side, locate the word Password and double click it Delete the contents of the Value Data field and click OK Close the regedit window Make the system bootable into DX7000 software: Click START Select Run In the Open field, type SYSEDIT then click OK Click on the SYSTEM.INI window within the System Configuration Editor window Locate the SHELL statement and remove the semicolon that was placed there earlier Close the System Configuration Editor window Click OK when it prompts you to save changes made to SYSTEM.INI file Restart the system (Click START > SHUT DOWN > RESTART) Click OK
Apr 01, 2012 | Pelco DX1000
MRB Error message on Gateway laptop 6510GZ. how can we resolve?
First of all I'm not this smart. I found it and pasted it here for you from:
http://www.pcpowerguide.com/windows/damaged-mbr-error-message/
They get all the credit!
MBR is the acronym for Master Boot Record. The master boot record is located in the boot section of your hard drive, which is the first sector on the first platter. When you boot your computer, the master boot record tells the computer's BIOS (Basic Input Output System) where to find the bootstrap code for the operating system.
So if the MBR is corrupted, the BIOS can't find the operating system and you can get error messages like the following ones:
  • Missing operating system
  • Error loading system
  • Invalid partition table
Looks pretty scary, doesn't it?
However, it is usually not that hard to fix a corrupted MBR and usually the rest f the hard drive is just fine and will boot normally once your fix the master boot record.
What Causes Damage to the MBR? A lot of things can cause damage to the MBR such as viruses designed to corrupt the boot sector. Some of them copy the original MBR to another file. Others do this by overwriting the MBR with virus code. In fact viruses and malware are one of the most frequent causes but, any file can become corrupted especially files that are accessed as frequently as the MBR.
How to Fix the MBR The stapes to fix the MBR are slightly different in the different versions of Windows. So I will cover them separately.
Windows XP
  1. Insert your XP installation disk in the CD-Rom and reboot the computer
  2. When asked, press any key to boot from the CD
  3. When you get the Welcome to Setup screen, press "R" to open the repair console
  4. Enter your administrator password when prompted
  5. At the command prompt, type fixmbr and press enter
  6. When a new command prompt appears, type exit
  7. Remove your installation CD
  8. Restart the computer
Windows Vista
  1. Insert your Vista installation disk in the CD-ROM and reboot the computer
  3. When you get the Install Windows screen, fill in the language and location options and then click Next
  4. Click on the Repair your computer option
  5. Select the Windows Vista operating system and click Next
  6. Enter your administrator password when prompted
  7. In the System Recovery Options, select Command Prompt
  8. When a command prompt appears, type bootrec.exe and press enter to fix the MBR
  9. When a new command prompt appears, type exit
  10. Remove your installation CD
  11. Click Restart in the System Recovery Options window
Windows 7
  1. Insert your Windows 7 installation disk in the CD-ROM and reboot the computer
  3. When you get the Install Windows screen, fill in the language, Time and Keyboard Input options and then click Next
  5. In the System Recovery Options, select Command Prompt
  6. When a command prompt appears, change to the boot directory
  7. Now type bootsect /nt60 SYS and press enter to fix the MBR
  8. When a new command prompt appears, type exit
  9. Remove your installation CD
  10. Reboot the computer
Aug 14, 2011 | Gateway 6510GZ Notebook
Windows XP
www.apple.com
This should fix all of your problems.
Jul 15, 2009 | E-Machines eMachines Desktop PC
Internet explorer will not allow to go to secure settings
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows
Solutions
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration.(this can be done by tapping the F8 key while booting and selecting last known good configuration)
  1. Insert the Microsoft Windows XP CD into the computer. Note: If you have a system recovery CD or restore CD (not a Microsoft CD) these steps will likely not work for your computer.
  2. Reboot the computer with the CD and press any key when prompted to press any key to boot from the CD.
  3. Once in the Microsoft Setup menu press R to open the recovery console.
  4. Select the operating system you wish to use; if you only have Windows XP on the computer you will only have one prompt.
  5. Once prompted for the password enter the Admin password and press enter.
  6. Once at the command prompt type bootcfg /rebuild to start the rebuild process.
  7. The rebuild process will step you through a number of steps depending upon how many operating systems you have on the computer and how the computer is setup. Below is a listing of the common steps you are likely going to encounter.
    * Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
    * Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter "Microsoft Windows XP Home edition".
    * Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
  8. Once you have completed all the available options in the rebuild and are back at the prompt type exit to reboot the computer.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
Jun 04, 2009 | Gateway GT5656 Desktop PC
Resetting iTunes administrator password
Which Operating system is it ?
If you have forgotten the admin pwd then you can try the following :
You need to bootup into single user mode (command+S at startup). It will take you to a command prompt. From the prompt you can do:
passwd user
Where user is the shortname for the admin account (you can lookup the shortname from the System Preferences->Accounts pane before you boot into single user mode). You type in the new password twice .. then type:
reboot
voila.
OR you can try...
At command prompt:
1.type: mount -uw /
2. press enter
3. type: /usr/libexec/register_mach_bootstrap_servers /etc/mach_init.d
4. press enter
5. type: netinfod -s local
6. press enter
7. type: SystemStarter
8. press enter
9. type: passwd root
10. press enter
11.type: reboot
12. press enter
Dont forget to rate this!
Dec 01, 2008 | Apple iPod classic MP3 Player
Trying to start from scratch
Hi Use the following steps to open a command prompt environment and also make sure tht the OS disk is in the drive:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears. The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
  4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: diskpart
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name and press the Esc key.
    • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name , type exit when done, and then press Enter
  7. Use the following steps to replace the boot.ini file with the backup boot.ini file:
    1. Type the following at the command prompt: X: (where X is the drive letter).
    2. At the prompt, type the following: ren boot.ini boot.in2
    3. Press Enter
    4. At the prompt, type the following: ren boot.bak boot.ini
    5. Press Enter
    6. At the prompt, type the following: exit
    7. Press Enter The system automatically restarts. If Windows XP does not open, continue to the next Step.
    If the above steps doesnt work then you will have to reinstall OS with the disks.
Feb 13, 2008 | Toshiba Satellite A105 Notebook
Dell (E210882) Motherboard Logo
668 people viewed this question
Alun Cox
