Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick LX -charging problem -need outside cradel with charger -
Does someone sell this type of charger ,thank you
  • 66 Answers
You can get the charging port on the phone repaired by www.fixphonenow.com for $55
Posted on Nov 16, 2008
How to fix sidekick lx battery when not charging
ytou need a volt meter to check your alternator output, alt out put should be around 14 volts while running.
Aug 30, 2012 | NRS Car Charger For Sidekick LX, Sidekick...
SiDEKiCK LX CHARGER PORT BROKEN??
sound like you need a new battery or charger or maybe both. try useing a diffrent battery and charger befor buying one
Aug 27, 2009 | Cell Phones
Tmobile sidekick3 wont charge
It's called the sidekick 3 charging port and they are known to go bad a lot.
You can check out cellulardr for the repair. It runs about 75 dollars or you can get a external battery charger cradel and charge the battery outside the phone.
Feb 17, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekcik Lx will not charge.
Try a new battery for it.
Sep 09, 2008 | T-Mobile Sidekick
Sidekick wont turn on
If you can, try a friends battery, either from a sidekick ID or sidekick 3. The Sidekick ID seems to be having the same issue as the sidekick 3 whefre the charging port goes bad. The best worka round for that is to get a charginfg cradel that has a spare battery slot.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 23, 2008 | T-Mobile Sidekick ID Cellular Phone
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Feb 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 powers down
The Sidekick 3 has an issue with the charging port going bad. It sounds like your may be having this issue. That or your charger is going bad. You battery sounds like it may be an issue as well.
The charging port issue can be worked around by getting an cradel with a spare battery charger slot. An extra battery is a good idea as well. That way you can have one charging with the other one is in use. A new battery and a cradle charger go for about 30-40 dollars on ebay.
Check out Sidekick Battery Charger to see whats available.
Jan 19, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick
Is it a sidekick 3? If so, is it under warranty? If yes, call t-mobile. The sidekick 3 is known to have an issue with charging ports going bad.
If not under waranty, it will run around 100 dollars to fix.
The other option is to get an external charging cradle and a spare battery. Make sure the cradel has a spare battery chargin slot. This will allow you to allows keep one battery charging and one in the phone. Both items will run about 40 dollars on ebay.
Check out the link below for some more info.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Dec 12, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
Sad to say, this is a common problem with the sidekick 3.
The charging port probably has gone bad. If it is under warranty call t-mobile.
If not, you can have it repaired but it can be pricey.
A workaround is to buy a sidekick charging cradel with a spare battery charging slot. An extra battery makes this easier. This will allow you to charge your battery outside the phone.
Both will cost you about 40 dollars total on eBay.
Sidekick 3 Charging Problem
Oct 31, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
451 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
