I have no spark-ran fine last week
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
SOURCE: toro recycler runs like ****
You will need to disassemble the carburetor and spray
with carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or the jet in carb. These portals can become blocked. Replace the diaphragm as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
SOURCE: 22'' recycler won't start
TRY A SPARK PLUG, MAY HAVE GOTTEN SOME WATER, MAY HAVE TO CLEAN OUT CARB
SOURCE: electric starter not working on Toro
I've had the same problem (I think) - the starter will not activate. First time, I found the fuse that's attached to the battery "tray" had corroded. For that I put a good coating of silicone dielectric grease on the fuse contacts and holder. This keeps moisture out. With that it was good for a few months. Now it's gone bad again. This time the fuse is good, but the battery is dead, and so dead that it won't recharge. Apparently the cause of the discharge was/is grass and moisture finding its' way into the battery area, and providing a conductive path between the battery terminals. I was recharging it regularly, following the owners manuals' instructions, so it's definitely not a negligence problem caused by me.
So, obviously what we have is a design flaw in the mower that allows grass clippings to get into the battery area. Time for a recall, but for a quick fix for your current pioblem, you might just find the fuse is corroded, and a replacement + non-conductive grease may be all you need to git'er going.
SOURCE: I have a Toro 22
Youwill need to disassemble the carburetor and spray withcarb.cleaner.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
Just let me know.
Jim
