I am using vista and have adobe acrobat, when i click on an online link to a pdf file it says 'acrobat not found' i have added the program to the list of accepted programs in the firewall but still no joy.
  • 4,806 Answers
Try downloading adobe reader 9 or 8 and install it over you existing adobe reader, adobe acrobat is an old bit of software which is obsolete now
Posted on Nov 15, 2008
What is pdf
PDF is a kind of file format introduced by Adobe Inc in 1993. It has the feature of non-editable and easy to share, so widely used in all over the world.
There are many tools could help us to create a PDF file, such as the famous Adobe Acrobat Pro and Nemo PDF series tool. They are both great choice for you.
Jul 07, 2011 | Microsoft Windows XP Professional With...
Tip
PDF Password Recovery 5.0 is an easy-to-use tool designed for removing asswords...
PDF Password Recovery 5.0 is an easy-to-use tool designed for removing asswords added to Adobe Acrobat PDF documents. It helps to decrypt protected Adobe Acrobat PDF files, which have "owner" password set, preventing the file from editing(changing), printing, selecting text and graphics(and copying them into the Clipboard), or adding/changing annotations and form fields. Pdf decrypt is being done instantly. Decrypted file can be opened in any PDF viewer without any restrictions -- i.e. with edit/copy/print functions enabled. All versions of Adobe Acrobat are supported. It also recovers document open passwords. http://www.recoverlostpassword.com/products/pdfpasswordrecovery.html
on Jul 12, 2010 | Computers & Internet
I cannot open files on my computer that require them to be open by adobe which I have on both my laptops. The files save then you have to open them with a program but it trys to open with word which does...
I assume that you mean Adobe Acrobat reader. First of all make sure that you already have installed this program. Go at start - programs - and browse all programs to locate that Adobe Acrobat Reader existing. A good idea is to open it in order to check that it's fully working. In case of a problem download it from this official link. Since you are sure for the Acrobat Reader's existence, right click at any pdf file (these type of files open with Acrobat Reader) - choose open with - go at the bottom of the new window "choose program" - at the new window select Adobe Acrobat Reader (in case it is not available click on browse and navigate at the C:\Program Files\Adobe\Reader x.x\Reader, select the file AcroRd32, hit open - check the box for "open this kind of files always with the same program" - hit OK and you are ready. From now on every time you will double click at a pdf file the Acrobat Reader will open this file.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 05, 2011 | Adobe Computers & Internet
How can i edit in pdf files
Go to these links for futher information:
How to Edit PDF Files Tutorial
http://www.investintech.com/products/desktop/editpdf/
Adobe Acrobat Tutorial
http://gsw.edu/~oiit/techsupp/acrobat.html
How to edit PDF files
http://www.prepressure.com/pdf/basics/editing
How to Edit PDF Files without Adobe Acrobat
http://www.labnol.org/software/edit-pdf-files/10870/
Jun 30, 2010 | Adobe Acrobat 7.0 Professional
Suddenly all my pdf docs are opening in Adobe reader instead of Acrobat Pro. Even the Acrobat.exe file in my C:Program Files\Adobe\Adobe Acrobat 7.0\Acrobat folders opens Adobe reader instead of Acrobat...
Go to My Computer. Tools > Folder Options > File Types > Then Browse PDF Registered File Type . If you can see " Details for PDF extension " and you can see a change button, you can click that button and browse for your Acrobat Pro main program .
Aug 18, 2009 | Adobe Acrobat 7.0 Professional
Missing Resource File
Solution: Remove Adobe Reader 7.0 and reinstall it.
Remove Adobe Reader 7.0, reinstall it into the Program Files/Adobe/Acrobat 6.0 folder, then try again to create a PDF document with Acrobat Elements 6.0.
1. Remove Adobe Reader 7.0 using Add or Remove Programs, and then restart.
2. Install Adobe Reader 7.0: At the Destination Folder panel, click Change Destination Folder and select Program Files/Adobe/Acrobat 6.0. Click OK, then Next to continue the install.
Background information
Acrobat Elements 6.0 is designed to work with Acrobat Reader 6.0. In order for Adobe Reader 7.0 to work with Acrobat Elements 6.0, install both applications in the same directory. Install Acrobat Elements 6.0 first, so you can install Adobe Reader 7.0 and select Program Files/Adobe/Acrobat 6.0 folder as the destination folder.
plz follow this link for further help
Mar 15, 2009 | Adobe Acrobat 6.0 Professional for PC
Can't download pdf file in yahoo mail even after installing adobe
Hello.
Seems that for some reson pdf files are assigned to your microsoft paint instead of acrobat reader.
Try this....
Find an already existing pdf file somewhere on your computer and right click on it and chose properties,
A box will come up where you now click the button that reads "Change".
A list of programs will appear where you now chose acrobat reader.
That should do it.
Regards..
/Tech5508
Feb 15, 2009 | Yahoo Mail
When I try to open a pdf file, the icon is different and does not open in Adobe, but in MS Word 2007, which of course is does not open properly. This computer (Gateway M6752 laptop)has Vista Home Premium,...
Hey mrbickham,
In some instances, updating existing software or installing new programs onto your computer can cause issues such as what you have encountered. Fortunately, re-associating .PDF files with Adobe Acrobat Reader instead of MS Word 2007 may be all that you need to do. Most versions of Windows allow users to select the program they want to use to open any given file type, and can usually be done by following the steps I’ve provided below.
1) Right-click on the .PDF file icon.
2) Choose "Open With" from the menu that appears.
3) When you highlight the “Open With” option a submenu should appear. Click on the link in this menu that says “Choose Program.”
4) Another window should then open, providing a list of the available programs on your computer. Choose Adobe Acrobat Reader from the menu and check the box next to it.
5) At the bottom of the page there should also be an option that says something similar to "Always use this program to open this file type." Make sure that this option is enabled.
6) Click "OK."
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 23, 2008 | Computers & Internet
I have windows Vista and loaded the newest Adobe Reader, but my computer will not open .pdf files that are sent attached to an email. I have uninstalled Reader and reinstalled it twice, to no avail. Any...
Do you get a dialog box saying that the file can't be opened? and down the bottom is a button with which you can select a program to open the file with?
If yes, click on this - Acrobat may not be listed (hence the problem). There should be a Browse button, click on this an work youur way to C:\Programs\Adobe\Acrobat (or some such naming) enter the Acrobat folder and find the Acrobat EXE file - click on this and say yes to all the prompts on your way out. This will now associate Acrobat with PDF files.
Hope this works.
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
