Question about Panasonic NN-T990SA Microwave Oven
Lightbulb no longers turns on!
The lightbulb in my Panasonic NN-T990SA microwave no longer turns on! I've had the more-than-reliabe microwave for the past six years; so I suppose it was time for it to burn out...the problem is, I called Panasonic and they say it's not "consumer servicable." You'd think for such an expensive microwave they'd put in a small bulb access panel to replace it, but they're telling me to send it to a local store for repairs. Help! I'm highly tech savvy, and I'm thinking about opening the microwave case and replacing the bulb myself (since it's waaaay out of warranty already) My questions: #1. Does anyone have any suggestions/tips to go about opening and replacing the bulb in this microwave? #2. What do you think the fair price is that I should pay a service center to replace a bulb in a microwave?
  • Erik bouy Dec 04, 2006
    Thanks MicrowaveSvc....do I STILL need to discharge the high voltage capacitor even if the unit has been unplugged? (Of course, I wouldn't open it up to this point with it still plugged in)...if so, how do you discharge it? I'm thinking in computer terms were you ground yourself to the something with a grounding wriststrap, which I have, or simply touch another metal object besides the one your working on in order to "discharge" any static electricity in one's body...
    Thanks in advance...
    -eb
  • Panasonic Master
  • 9,156 Answers
They do this to avoid liability from your exposure to the instantly lethal voltages present in and generated by your microwave oven. For important safety and disassembly tips, search on Yahoo.com (not Google) for all this at once (copy & paste): microwave disassembly.txt safety.txt The oven must first be disconnected from the power line. The outer cover is held in place by several screws on the back and sides, then you lift up and back from the rear to remove it. You need to avoid the sharp metal edges on thge cover and inside the oven. Note there are also catches built into the top & sides of the cover which must be re-engaged upon reassembly, or the cooling efficiency will be compromised. Once the cover's off, if there's any chance you might come into contact with any of the high voltage connections, the high voltage capacitor should be discharged for safety's sake. Once the bulb is located, it can be unscrewed and replaced.
Posted on Nov 22, 2006
SOURCE:
How to change a lightbulb in a model nn-656ba panasonic microwave oven
I may be wrong on this model, but most microwaves need the top/side panels removed to get to the. Light. Afer removing the screws raise the back a couple of inches then slide cover towards the rear in order to slide the top potion out of its retaining clips. They do sometimes get stuck with food etc.
Oct 14, 2014 | Panasonic NN-P794SF Microwave Oven
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
Change the lightbulb on a NN SD967 microwave
I can't find anything in your manual nor can i see detailed pictures of the outside of the microwave but if you see a panel on the outside left of the unit undo the screws to get at the bulb.
Nov 29, 2013 | Panasonic Replacement Part For Microwave...
How do I change the lightbulb in the Panasonic inverter microwave?
Howdy. Bad news; that is not a user-repairable part according to Panasonic. They recommend a local repair shop. I was going to send you the link to the manual anyway, (in case you are a hardcore DIY person) but that model is no longer supported on Panasonic's site. Sigh.
If you have any trouble locating a decent repair specialist in your area, I'd be happy to help out with that.
Farmerbear at FixYa.com
Sep 13, 2010 | Panasonic NN-T551 Microwave Oven
Panasonic NN-T990SA mfg 2002 Door opens, tray continues to spin-light on-fan on--not cooking.
call the toll free number for the product, service centre might assist, I would not use until fixed
Sep 03, 2009 | Panasonic NN-T990SA Microwave Oven
My microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Turns off after 3 sec
Usually this indicates failure of the magnetron and/or the inverter. Neither is easy to test without specialised HV equipment. Often the cause is operating the oven without anything in it. If this has happened, it will generally be failure of the magnetron.
Replacement of the magnetron is relatively easy (about 15 minutes) and the inverter a little longer but if you do not have the knowledge/skills please do not do it - there are very dangerous (deadly) voltages associated with magnetrons even after they have been switched off.
Cost of magnetrons ranges upwards from USD25 to USD100 (from Panasonic spare parts) and inverters range upwards from USD125. The cost of parts is often the reason microwave ovens are not repaired.
Doug
Nov 05, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
216 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
