Question about Philips CCA134AT 13 in. Combo
TV/VCR combo - tape is stuck, will not eject and shuts off TV
Is there a way to get a stuck VHS tape out of a TV/VCR combo? I've taken the back off of the TV and pushed every lever that looks likely. I tried forcibly (gently) lifting the little plastic wheels that will bring the tape up, but no luck. I can't figure out how to get this thing out of the TV. Help! (p.s. what brilliant person decided to create a TV that would only work if the VCR was working?!!)
  • Anonymous May 10, 2009
    After rewinding a VCR tape, it won't eject, play or fastforward. There must be a way to manually eject the tape, but I can't find it. How can I get the tape out?
premtech
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
techman
  • 3130 Answers
SOURCE: Stays on for 5 seconds, thinks it has a DVD or VHS tape in
I am afraid the set has a bad or broken tape transport, or better known as a bad tape carriage.
Posted on Jun 20, 2007
  • 28 Answers
SOURCE: VCR TAPE IS STICK IN VCR PLAYER.
if you can't get the tape out enough to pull it very carefully out by hand, you'll have to bring it to a repair shop. the tape is probably twisted up inside and jammed.
Posted on Nov 09, 2007
  • 4102 Answers
SOURCE: Looking for a manual for a Philip TV combo (TV and VCR)
hi,
click here
click on the blue writing and it will take you to a site that has two manuals listed that you can download for free.
If you have any problems just give me a shout back and ill be glad to assist you further.
Also let me know if its the correct manual it should be but you never know untill you look ok.
Posted on May 19, 2008
  • 4234 Answers
SOURCE: TV/VCR combo unit trying to eject non-existent tape
The problem is that the loading is out of timing by a tooth. This would explain both the attempt to load a non-existant tape as well as the unit shutting down. This unit needs to be disassembled and the belts replaced and the loading mechanism re-timed. I have done many of these with success. While time consuming because the entire unit must be taken apart, it is not a real difficult repair for anyone that has done them in the past. Where are you located so I can make a referral?
Dan
Posted on Apr 09, 2009
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
My daughter put a vhs in her vcr/dvd combi. Now the vhs is chewed and stuck so it won't come out and the tv and dvd player automatically shut off
Take dvd/vcr combo aparts.Turn on the power to the machine,one hand move around the inter eject vcr port for those sensors,the other hand just keep pushing the eject button,keep doing this until the tape eject and come out.
Jun 14, 2010 | Televison & Video
VHS tape only partially goes in & then automatically ejects Panasonic PC-C1332W 13 in TV/VCR combo
sounds like there is a tape in it you are not aware of ,it may have one (vhs tape) stuck in it.
larry
Nov 22, 2009 | Panasonic PV-C1332W 13 in. TV/VCR Combo
Trys to eject movie, fails, then shuts off...
the tv must unscrew the cover turn the power felds around for vcr cage for sensor the tape will pop out.push the eject button doing this.
Aug 13, 2009 | Funai F3819D Combo
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
Emerson Television
cambiale las bandas de la casetera
Nov 14, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
Televison & Video Logo
245 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
