Question about Amana AOCS3040 Electric Single Oven
F9 code I set the oven to clean and left it. It did not clean and now I have a code that flashes when I push any of the buttons to bake with. The code is F9 and it has to do with the door lock. My oven won't heat or bake because of this code. Any suggestions on how to reset the oven. I have tried the breaker already...Thanks...James
  • 5 more comments
  • Anonymous Nov 21, 2007
    I have the same code and the door will not open. It all started with the self cleaning
  • Anonymous Dec 11, 2007
    I'm havong the same problem with my oven. I have tried to break in it but I couldn't. So I'm asking for your help on what I should do to fix this problem that i'm having.
    Thanks,
    Charles
  • jana74 Apr 07, 2008
    i have f9 code and i canot open oven what i should do????
  • Anonymous Apr 13, 2008
    We are having the same exact problem.
  • Anonymous Jun 03, 2008
    Same problem it is so annoying.
  • stp6785 Sep 27, 2008
    My wife pushed the self clean button and shortly afterward F9 error and PF came up. We replaced the motor latch motor to no avail because that is what the manual said was wrong. Well I am so glad a guest solved this problem with Amanas help otherwise Sears wanted $475 to replace the board. Unplug your oven and then plug back in PF is lit up and the oven goes into clean mode I just pushed bake and it cleared it up oven working again how simple was that. NO More self cleaning and all this cost me $225 and Sears and the other idiot I had come to diagnose the problem really make me proud to know how smart they really are.
  • beck3660 Mar 13, 2009
    Followed the instructions--circuit breaker off, breaker on, bake button, then pressing the small/inside button. Did it work? No.
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Posted on Jan 08, 2009
Digital lites on my control went out. The lock on the door activated. The time will reappear when the stove burners are turned. Otherwise, there is no lite on the screen.?????
Posted on Mar 24, 2011
We tried resetting the circuit breaker several times and it wouldn't work. Amana told us to set it to bake and see what happened. When it clicked on in Bake mode, the F9 code disappeared and the door unlocked. Good luck.
Posted on Sep 03, 2008
  • 3 Answers
Hi~ According the the manual the code F9 - door lock or circuit malfunction. Try either pressing oven cancel or disconnecting and then reconnecting the electrical supply (circuit breaker or fuse). If this doesn't help, the only other option is to call a servicer or the company directly for other solutions. The manual is not as helpful as you would think it should be. Linda :)
Posted on Dec 30, 2007
SOURCE:
I get an F9 error message when I try to set the oven to bake.
THis is what the F9 error code means;
F9 Door latch failure Replace door latch switch or assembly if necessary
Aug 20, 2011 | Ovens
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Amana ACB6260A Electric Double Oven
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Pushed the clean button, the oven locked, and the screen started beeping and flashing f9 or f7. I hit cancel, and the oven is still locked and the clean button is sill flashing.... It has been 10 hrs!
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^%$
Jun 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door is open, but F9 now signals, trying to turn on
HI. this F-9 code is signaling a major door mechanism malfunction. the best action is to replace the entire door latch assembly. this will heel the F-9 alert and, fix the problem you are experiencing at this time.
Please rate and, have a great evening:)
Jun 16, 2009 | Amana AOCS3040 Electric Single Oven
Hit the "clean " button on my gas stove. Not only did it not clean but the Door locked button has been flashing for 2 weeks. Everytime I go to cook and it the Bake, Broil key it flashes DR then F9 I h
Personal opinion. Do not mess with settings on a gas stove. Call a gas oven repair tech and have them come out and fix it. That way if it happens again you have someone to call
Nov 03, 2017 | Frigidaire (FEB30S7D) Oven
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Amana AOCS3040 Electric Single Oven Logo
2,470 people viewed this question
Top Amana Ovens Experts
Steve Allison
Steve Allison
Sal De
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
