Question about Speed Queen AWS52NW Top Load Washer
Hot water trickles into the tub
When I put the water on hot, it trickles out. I checked the hose and screen, they are clear.
HELP!!!!!!!!!!!!!!
    Genius:
  • 1,028 Answers
If screen inside fill valve is clean and plenty of hot water to valve replace valve
Posted on Nov 15, 2008
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water into tub of wash machine
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Mar 05, 2009 | Kenmore Washing Machines
Cold water feed into tub seems somewhat pluged.
8. re-try.
The cold water does not run it trickles, hot water runs very fast
If both solenoid coils check the same, you probably have a clogged supply hose. Check that the filter screens inside the hose (if present) and the fill valve inlet are clear of mineral buildup. Try switching the hot and cold supply lines to see if the trouble moves from cold to hot. If the cold still only trickles in, replace the fill valve.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Hot Water won't fill
I like to put the hose over in the tub and run some water just to eliminate plumbing problems from that point back. Then, I check the inside of the water valve where the hose connects which you have done. If all this is ok the only thing left is to replace the water valve. I have had some success taking the water valve apart and cleaning it out. About 2 out of 10 will start working but most require replacing.
Jan 24, 2009 | Maytag Washing Machines
Cold water only trickling into my washing machine
unfortunately it sounds like you have a stuck plunger in the cold side of your water inlet valve.if the screens are clear and your water pressure is good,thats what you have.
Sep 25, 2008 | Washing Machines
Speed Queen AWS52NW Top Load Washer Logo
143 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
