Question about Toto Aquia II Dual Flush Toilet
What is the diference of 12'' rought or 10''on a installation
For a toto aqua 2
  • 43 Answers
If you have a 10" rough in your house you can not install a 12" rough toilet. but if you have a 12" rough in your house you can install a 10" rough you would just have a 2 inch gap between the toilet and the wall.
the rough is measured by measuring the middle of the sewer hole. that your toilett sits on. to the back of the wall this is important because the tank sits behind the toilet. if the tank is too big then the toilet wont fit over the sewer hole.
your house shouldnt have a 10 inch rough unless its about 90 to 100 years old most home's now days go off a 12" to 14" rough.
if you do have an old home you can order any 10" rough toilet at a plumbing supply store. or lowes. they probably wont carry them in stock though because 100 year old houses aren't very common
Posted on Nov 16, 2008
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
How to stop Toto toilet running? After flush, bowl fills up completely and water continues to run. Jiggling the handle has no effect because cap at end of chain is fully seated. Brand number: Toto...
1. CUT THE WATER OFF AT THE WALL 2. PURCHASE REPLACEMENT INTERNAL UNIT FOR 10 BUCKS AT WALMART 3. INSTALL IT WITH THE INSTRUCTIONS PROVIDED 4. PROBLEM FIXED FOR 10 BUCKS
Jan 26, 2011 | Toto Home
New Rainbow aquamate. It is not letting the water flow through.
Sometimes it takes up to 10 or so minutes for the Aqua mate 2 to begin pumping out anything.
If it is the new Aqua mate 12 (the big blue one, that is like a giant power head) the same thing is true for it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Dec 22, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Toilet - 14 inch rough in
Hrm, I see what you mean and this may be a bit late.
The 14" rough in is not standard (as in 12") and the depth (from the back of the tank to the front edge of the bowl is your concern here?).
Kohler also has a Sterling brand with the Windham model. This will sit on the 14" rough and measure less than 30" from the back wall.
You could also go with a Toto ($$$ concerns) as they have a unifit system that allows for adjustment from your roughed in closet/toilet flange. It basically mounts to your flange and then sets back 2" or 4" depending on which model Toto toiler you are installing. The Soiree-?sp may be your best bet for depth concerns, but not so good for your wallet.
Chris
Jun 13, 2009 | Crane Plumbing Toilet To Go Tall...
Philips 37PF9975/12
yes i owuld go that rought 1st power suple do u know how to install these if not take it in u can fry it up ore if u dont unplug it in right order
Oct 06, 2008 | Philips 37PF9975 37 in. HD-Ready Plasma...
Second hand at 6:00 instead of 12:00
you simply pull out the crown then push the button at 2 o'clock as many times as needed to return the hand to 12.
Jun 16, 2007 | Aqua Master Men's Diamond Encrusted Watch
Toto Aquia II Dual Flush Toilet Logo
320 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
