Network card disabled - Computers & Internet
  • 4,806 Answers
Go into device manager and re-enable it, it will be under network controllers
Posted on Nov 15, 2008
Phone disable! network lock
Is your phone disabled or asking for network unlock code?If it is disabled...then you can contact the nearby mobile store...If it asks for network unlock code...you can approach Classicunlocking.com and specify the model, country,locked network of Siemens phone.Based on the availability you can get the unlock code along with free instructions.
Apr 02, 2014 | Siemens Cell Phones
Tip
How to Unblock Network lock of SAMSUNG SGH-J700
SAMSUNG SGH-J700 UNLOCKING:
1- Power on pone ,, type : *#7465625#
you will identify which code is active , which is inactive
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on pone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your pone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your pone should work and accept the sim card ,, but if you check locks you will find that your pone is still Locked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now ,
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,Here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
on Jan 21, 2010 | Cell Phones
Internal communication error how to fix this problem
check your network card maybe it was been disabled. But if the network card is already enable just do disable and enable once it state connected then try surfing the net . hope it helps. Thanks
Sep 13, 2011 | Opera Software Computers & Internet
0x00000103
System stop code 0X00000103 is caused by a network card error. Try to disable the network card in the device manager and see if that resolved the issue. If it does, attempt to reinstall the drivers for the network card. If reinstalling the drivers does not fix the issue, then replace the network card.
May 16, 2011 | Computers & Internet
Blackberry bold 900,with initialization failed when i inserted my chip, when the network is activated it reads insert a Sim card,this was after swapping the chip into a modem but back into another phone...
You need to unlock your blackberry network. Go to find blackberry bold 9000 unlock code for your original network sim card so your phone will be unlocked for another network. You can get blackberry unlock code from your provider or you can buy from third party sites for the simple way.
Apr 18, 2011 | RIM BlackBerry Bold 9000 Smartphone
NIC card
Right click on My computer
go to Properties
Go to Hardware
Go to Device Manager
Click on the +sign
Right click on NIC to disable and enable it
May 03, 2010 | HP Pavilion dv6000z Notebook
I am facing network problem since two days back. plz give me advise what should i do manually.
There can only be 3 problems
1. the network card is stuffed, or disabled - to enable, go to your Control panel, select System, select Device manager, Select Network Adapters, Select your Network Card, right click and select enable(if disable is displayed, then your card is fine)
2. the network cable is faulty - try a new or other cable
3. the network plug, where the cable plugs in at the wall is faulty, or not patched in your server room - this must be sorted out by your Network administrator
Dec 30, 2009 | Nokia 1110i Cellular Phone
Hello sir, my system has been conducted a problem. lan card is disable so . i donot know how to enable lan card please give me a solution. thanking you
if the lan card is disabled then you have to reseat the lan card if that is a external lan card connected & not the integrated one..also check for the network adapters if they are installed under device manager or not...in case not you also have to install network adapters...
Apr 29, 2009 | Computers & Internet
Network card is dead
you can disable it in bios settings if its onboard remember to save on exit
Mar 02, 2008 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Disable LAN adapter
Hi, If you are using XP you can disable the network adapter by going to "Control Panel" then "System" click on the "Hardware" tab and then on "Device Driver". In the list find your "Network Adapters" and open it to see your actual card. Right click on your card and select "Properties". On the panel that displays, right at the bottom near the "OK" button there is a drop down "Device Usage" text box, at the moment it would be reading, "Use this Device (Enable)". Click on the Drop down arrow and and select the "Do Not Use this Device (Disable)" option and then click "OK"
If your PC is a desktop type with a network card in one of your PCI slots, or similar, you could also actually remove the adapter card simply by removing the outer case covers and then unscrewing the nut holding the card in and carefully pulling it out quite firmly in a straight motion. You may want to get another small metal cover strip to screw in where the card came from.
Before opening your PC though be sure you are not voiding any warranties that you may have got when you bought it.
Oct 26, 2007 | Panasonic UF770 Laser Printer
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
