Question about Sony KV-32FV1 32" TV
20" Samsung TV
Hi, My TV Samsung does not power on but the standby light is on,As in it was freeze.I've checked the power supply circuit but I can't see anything defective.Is it the regulator that cause the freeze?I'm also a technician.
  • 1 more comment
  • Renato Jardiolin Dec 06, 2006
    Hi to all,Has anybody experienced these problem.Hope your
    solution soon.Thank you.
  • lowly5 Mar 19, 2008
    samsung TV went off but when turned on again power LED flikers on and off but no image
  • Cabletv Thangaraj May 30, 2014
    power supply filter capacitor may be faulty
  • 65 Answers
The newer ones had a resistor parts change in the primary part of the switching power supply probably a yellow banded resistor for startup
Posted on Dec 09, 2006
No Picture on Samsung Tv model UN40EH5300f. Standby light is now on after installing new power supply. Need help on which part to buy now, inverter or mainboard?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
Mar 04, 2018 | Samsung Televison & Video
More detail --- Toshiba md20q42 tv/dvd combo not powering on, initially when it happened i Hit power button and lite came on and blinks for about 3 seconds then turns off--- now when i push power button...
Hi
It is probably a power supply problem associated with standby circuit. If this circuit is bad the set hardly comes on and fails. This is a task for a technician to trace the fault through the whole power supply.
Sully
Sep 22, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony TV turns off immediately after turning on
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Check this link to get more details about Sony Blinking codes.
Jan 13, 2013 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Hi my samsung crt tv come up on start up but couldn't stay for more than few seconds before it goes standby. I've tried to check settings but could not even get anywhere before it goes back to standby
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). Are you sure this is the model number of your television because this model number is not for a CRT television. For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 29, 2011 | Samsung LNT3242H Television
Tv sony stop after 20 min standby led flashes 3 times
HI,
By three blink it means the B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is because there is problem in the power supply circuit. Check for any dry soldering in the power supply side. If the tv is working properly for 20 minutes then its sure that there is some dry soldering joints in the power supply side. You have to resolder suspected soldering contacts using soldering ion and solder. The dry soldering joints will look like on in the picture.
ajin_g_109.jpg ok
Oct 06, 2011 | Sony KV-29FX66 29" TV
Samsung le32r74bd When I turn the tv off by the button the standby light comes on as it is in standby and I can turn it back on again with the remote control. How do I turn it off properly without it...
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where in the panel board.if otherwise power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Sep 16, 2011 | Samsung Televison & Video
SAMSUNG TXH1970... The standby light is on, but when I press the power button nothing happens.
Hello
There is some short circuit in the secondary side of the switched mode power supply section inside the circuit board. Now only the 5VDC is correct, as you see the standby light ON. The short is likely to the horizontal output transtor. Replace it first and see whether it helps you. If not line out put transformer is faulty, and should be replaced with same type and number..If any internal short occurs, the power supply protection system will activate, and shut down all other secondary power supply rails, as a protection to prevent further damage to more components, This is happening in your TV now. OK
May 22, 2011 | Samsung TXH1970 TV
LD3750HD
goodmansld3750hd, last comment as guest is now signed in as baldwin1972 hope i get a response
Dec 06, 2007 | Goodmans 257NS 20" TV
Sony KV-32FV1 32" TV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
