Question about Western Digital Caviar AC2340 .34 GB Hard Drive
Won't show device in hardware
I have a caviar 2340 from an old computer. I took out the drive and am trying to use a usb 2.0 ide adapter on my dell optiplex sx280 with window xp pro. Any one know if it can run on my dell.So far no go.
I think that on the old machine it was using window 98 .
Thank You for any help. Ken
  • ken5499 Nov 15, 2008
    On Slave
  • Lou Labetti
    Lou Labetti May 11, 2010
    What is the pin setting that you have on the hard drive?
  • 104 Answers
Ok, take the jumpers off of the drive or make it a master. That should get it to work
Posted on Nov 15, 2008
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
It doesn't fasten and alone it emits an out hooter
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 17, 2010 | Western Digital Caviar SE16 WD5000KS 500...
Wireless adapter not found please plug-in the DWA-120
After uninstalling it completely from the computer. When you plug in the adapter alone. You must get the "Found New Hardware" wizard. And nothing else apart from this. Only then it is correct. If nothing comes up at all, the device is dead or your version of USB might USB 1.0 or USB 1.1 which at times has issues. But if you see that wizard coming up, unplug the adapter and insert CD and run setup and walk through it.
Anyway, i ll recommend that you try this adapter on other NEW computer(laptop or desktop), just to check.
I feel that this adapter would work on a new computer, maybe your computer's hardware specifications are old to support this device.
copy.pngfavicon.icofavicon.ico
Jan 22, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
My XP PC won't recognize portable Western Digital hard drives
Not sure how to help without knowing what hardware you're using to read the drives.
But here are a couple of links from WD that may prove helpful...here and here.or here.
I'd look for something similar on the support site for your device.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 15, 2009 | Computers & Internet
Run wd1600 via ide-usb problems
Just replace the case the drive is in. You can get them from stores that sell computer parts like Fry's Electronics. There are many online sources too.
Feb 08, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Want to get music files off old toshiba laptop windows 98 no burner
hi evin
you could use a usb stick to transfer the music from laptop to other pc ?
riz.
Jun 23, 2008 | Toshiba Computers & Internet
Formated Hard drive from Ebay
Apparently you have tried most if not all of the basic install procedures.
If and when you connected it as a secondary or slave to a working/booting PC, was it auto detected at the CMOS/BIOS stage? If yes, then perhaps it is a partitioning/formatiing issue, if not then chances are that it is a hardware problem and the drive is dead.
Alternately, you can try using an external SATA/IDE Interface to USB such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter or any comparable product. This would provide the SATA/IDE connections to your new hard drive as well as a USB cord to your PC's USB port.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Western Digital Caviar (WD307AA) 30.7 GB...
Open Questions:
Toshiba Virus Removal ' Remove Toshiba Virus - DataAlign ' Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
May 23, 2018 | Toshiba Computers & Internet
See all Western Digital Caviar AC2340 .34 GB Hard Drive Questions
Western Digital Caviar AC2340 .34 GB Hard Drive Logo
187 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
