Question about Rosewill R900J 19" Flat Panel LCD Monitor
2 problems with two computer
I was fixing a cpu that has not been in used for a year...i was able to make it work but then again, after minutes, the monitor goes black..the light indicator tells that its off, it turn to oraange which is sleep mode..the problem is not with the monitor since i using the same monitor in my own cpu...it doesnt turn on again....
the laptop i was trying to fix has a virus....the anti virus cannot cleaned it, the options are deleting it and its not my option since the file is important to me or leave it....
" probably unknown NewHeur_PE virus"....
task manager has been disabled..i think the option here is reformatting..but i need the filesss...what is the best solution? pls..help me! thanks.. God bless
  • 19,396 Answers
About the CPU, replace the cooling fan, if it goes off always after same time, then is overheating.
About the virus, read the following:
If the antivirus is not enough use an antimalaware that removes more viruses use this one: Spybot - Search & Destroy - Free software download , install, update, and perform a full system scan.
If that is still not enough, the best thing to do is doing a backup of your files, and reinstalling Windows.
Posted on Dec 02, 2008
Thermal event issue
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 19, 2013 | Dell Dimension 4600 PC Desktop
CPU keeps overhreating.
Feb 24, 2013 | ASUSTeK COMPUTER ASUS P8Z68 DELUXE/GEN3 -...
My laptop's fan isn't working so my laptop shuts down on its own every nw and then which i guess is due to overheating.what should i do to repair this problem?
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 19, 2012 | Acer Aspire 3680 Laptop
I just used my Compaq laptop computer (Presario Cq40 108TU) this morning for 2 hours. This afternoon when I was about to use it, it turned on then while starting up it suddenly turned off. I tried again to...
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Mar 24, 2011 | Computers & Internet
My computer is not starting, no beeps, no lights except that the fans are working? the last time i used my computer it was working perfectly. after almost one year, when i switch my computer on, i noticed...
One of the most common failures is Power Supply. Try first, unplugging and leaving off for a few minutes before trying to start it again. Sometimes this helps, but I expect you will need to dig deeper.
Oct 20, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
My pc turns off itself
Check your cpu heatsink/fan. This sounds like an overheating problem as the cpu has a sensor that will automatically shut down your system to prevent it from frying. Hope this helps.
May 12, 2009 | Computers & Internet
One year old soyo topaz s DYLM24DC Monitor. OK for a 6 months, then my cpu started getting too hot and system crashed multiple times until I figured out about the temp problem. No overclocking. AMD 6000...
I am not 100% sure but I guess that the system board on the monitor has been overheated and therefore will require replacing.
You can get it tested but certified engineer local to you.
Please let me know how you get on. In the mean while I'll do a bit more research into this on your behalf.
Best of luck
Philip
Nov 30, 2008 | Computers & Internet
Xbox 360 3 Red rings of death
3 lights - hardware problem. I've seen repair instructions being sold on ebay.
But if you have warranty, you can get it repaired for free by microsoft.
let me know if you got any other questions before rateing the solution.
Jun 15, 2008 | Microsoft Xbox 360 Console
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Rosewill R900J 19" Flat Panel LCD Monitor Logo
26 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
