Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
Whirlpool Compactor: starts making banging noises....
I turn off. Bump unit in with my knee. start again and it will finally finish & unlock...what to do?
  • debbiezager Nov 18, 2008
    You were totally right - not under warranty anymore - gears were striped - repair is - ouch - almost as much as a new one! Thanks for trying!
    Sergeant:
    Champion:
  • 251 Answers
It sounds like there is something in the motor or a gear is getting ready to go out i suggest calling ge if it under waranty
Posted on Nov 15, 2008
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
Kitchenaid compactor KUCS03FTSS makes banging sound at end of cycle
I bought a Kitchen Aid trash compactor the end of Sept/2008. By July/2010 I have spent $528 on having it fixed! It only cost $623 new so I called Whirlpool customer satisfaction line where after waiting 15 minutes was told that "With all due respsect mam, Whirlpool owes you nothing" Then " as a courtesy" they offered me 50% off an $80 part that I still need to pay $60 in labor to install! So,that would be an additional $100 on an appliance that has been trouble from the get go...I have had numerous compactors before this brand and have never had any trouble...Do NOT buy anything made by Whirlpool as they have apparently, a NO customer satisfaction policy.
May 17, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Touch pad keys don't work, except the one to turn phone off
Oh my gosh!!!! It worked!!! It really worked! I had my phone in the back pocket of my jeans when I went outside in a heavy rainstorm to get to my car. When I got to school (I'm a teacher) I realized my phone wouldn't work...except for the power button. None of the other buttons worked at all...AND...GULP....the water indicator sticker inside was red. I got my second graders busy, then looked on here for some help on what to do. I read the comment about how the person laughed, but banged the phone on her knee after reading about banging the phone....not thinking it would work...and it DID! I'm SO happy!!!! Thank you
Mar 18, 2008 | Motorola Mobility RAZR V3
Trash Compactor Problem
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Nov 20, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
472 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De GO PATS
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
