HP 190 Copier
Problem for HP 190 Copier
HP Officejet 6300 All-in-one machine makes black streaks
By john754 on Nov 15, 2008
When I use the automatic document feeder to make black and white pr color copies the copies have a black streak down the middle of the page. This does not happen when I make indivudual copies by placeing the orginal on the glass plate. There are no black streaks when I use the machine to print a document.
Best Solution
posted on Nov 16, 2008
Very Helpful)
Cogz
Rank: Guru
Rating: 86%, 460 votes
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Was this helpful?
Yes
No
Popular Solutions for HP 190 Copier
Questions and Unsolved Problems for HP 190 Copier
Do you recommend HP 190 Copier?
Answer
Answer
Dirt under the glass
Answer
It has power, and two grey lines in the window... nothing else, won't print, won't do anything.
Answer
cartiges are jammedon hp color copier 190
Answer
Would like for you to recommend a place where I can get my mother's HP 190 copier cleaned for better... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in , FL
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
