Question about Hitachi Laptop 20GB (13G1489) Hts424020m9at00 20 GB Hard Drive
HTS424020M9AT00 hard drive will not boot up.
It is making a loud clacking noise and will not boot up. It is saying there is no operating system. We run ran XP
  • 95 Answers
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it if you need that data.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Posted on Nov 30, 2008
  • 104 Answers
If it is clacking you will need to replace your hard drive.
Posted on Nov 15, 2008
Rattling loud noise when plugging on & off adapter please help its annoying
A rattling noise can only be from one of three sources, two of them are mechanical. The first is the hard drive. If the hard drive is making clacking noises, it is usually soon going to fail. Now is the time to retrieve and save off any important files that you don't want to lose. The second would be the CD/DVD drive - but unless there is a disc installed they usually are dormant. The third could be from the sound card. This would be highly unlikely and indicative of a problem on the mainboard. I would lean toward the hard drive as the most likely candidate.
Dec 10, 2015 | Computers & Internet
Crackling noice on my laptop
Crackling or clacking? If it is continuous loud clacking, it might be your hard drive.
Sometimes you can hear the drive making noise which is normal because an update or something might be running in the background.
May 12, 2012 | Computers & Internet
Operating system not found , cos i took the hard drive cos after i tropped my laptop it starts to make noise and it wont start it tries to solve the problem but then it says windows cannot solve the...
Since the noise is associated with the hard drive and the system was dropped, then most likely you will need a new hard drive.
You can get a new drive at www.newegg.com among other places then once installed, boot to you Operating System disc and reinstall the OS
Jun 19, 2011 | Computers & Internet
Why does my Acer laptop sound like it's taking off ! There is a whirring noise form underneath on the back left, i thought it might be the fan but it starts as soon as i turn it on but after some time it...
Hi Ian check to see that you have not left a CD disc in the CD rom /dvd drive--- sometimes they will cause this sort of noise on start up when the computer is looking for an operating system it may look in the cd drive first and scan the non operating system disc before booting from the hard drive
I hope this helps
Andrew A
Mar 28, 2011 | Acer Aspire 5535-5050 Notebook
Loud Clacking Noise
timeing has slipped or cam broken
Aug 24, 2009 | 2003 Ford Crown Victoria
My hp pavilion 4200 i took the hard drive out and put it back in when i booted it up it says media cable not found then it says operating system not found. tried to run the operating system cd and it says...
The laptop can't find a hard disk, eirher the hard drive is faulty or not seated properly.
Take out the hard drive and reseat it again then see if the laptop boots up. If it still can't find the hard drive, listen to the hard drive, is it spinning up, is it making clicking noises? This indicates a faulty drive and needs to be replaced.
You can also test the hard drive by removing the hard drive and attaching it to a USB hard drive adapter and then plug it into a working computer's USB port. If the hard drive is OK then the computer will see it as an external drive and you can view and open the files.
Mar 08, 2009 | HP Pavilion ze4200 Notebook
Clicking Harddrive
Loud Clicking CAN be a symptom of a failing hard drive. Generally it is also associated with a boot failure though (It is called the Click of Death). If the system is booting normally, there may be a different source for the noise. Most desktop systems have a minimum of 2 cooling fans, higher powered ones can have 5 or more. Many moving parts in the system can cause a click.
I would suggest you remove the side cover of the tower, and see if you can localize the source of the noise. (The instructions for your system can be found on http://h10025.www1.hp.com/ewfrf/wc/siteHome?dlc=en&lc=en&cc=us
Once you localize the source of the noise, you can address the problem.
May 13, 2008 | HP Pavilion m7570n (EX331AA) PC Desktop
New laptop
Open the hard drive bay and make sure the hard drive is properly seated. close bay
reboot and enter bios to see if hard drive is detected in bios, if the hard drive is detected and still will not boot use recovery console to recover the OS.<ALT><F10>
If the bios does not recognize tthe hard drive, replace hard drive.
May 08, 2008 | Computers & Internet
Clacking noise hard drive on HP Pavilion dv2700 Laptop
Laptop hard drives can be a bit louder than the new desktops and because you're closer may be more noticable. The sound from that youtube is about normal - this video is the sound of the heads crashing - mechanical drive failure. http://www.youtube.com/watch?v=LRj6dP1Pi1Q
Just to be safe - BACKUP your important data and if you don't have the install disks, make a set.
Feb 28, 2008 | HP Pavilion dv9000z Notebook
Hitachi Laptop 20GB (13G1489) Hts424020m9at00 20 GB Hard Drive Logo
128 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
