Question about Kenmore 59940 Kitchen Hood
Fan runs but drive mechanism kaput
Hi guys, I've got this 6 year old downdraft fan. Complaint is that the drive motor runs without any movement up or down of the unit. Discovered it when in the down position. Manually raised it up, where it now resides. Blower fan works as advertised. any ideas? This appears to be the only piece of gear that the builder didn't leave me a manual or parts xmatic for - wouldn't you know... Thanks, Deano K. Beaverton, OR
5 Suggested Answers
  • 12 Answers
SOURCE: blower fan operation
I would order a new Controller Board. Depending on the exact version, it could be a problem with a relay, or a triac on the board, that are meant to power up the motor.
Posted on Jan 25, 2008
shaggyrat
  • 1224 Answers
SOURCE: Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Posted on Jun 01, 2008
jyackle5
  • 8197 Answers
SOURCE: Need to reinstall Kenmore Downdraft Blower
If I can get the model # I can help you more with the removal and reinstall.
Posted on May 29, 2010
Testimonial: "Thanks for the help!"
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
Downdraft up and down
Hi do you mean the air is increasing and decreasing on its own
Feb 22, 2008 | Thermador CVS30R Kitchen Hood
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
One mechanic believes the throttle control module is bad. He notes the car is staying in a higher gear. Which is what it drives like but it is intermittent. The air conditioning fan quit blowing and the...
Hi, Your mechanic could be right. Sounds like the engine is running too fast for transmission to shift properly. Have him look it over. Good luck.
Jun 15, 2011 | 2000 Chevrolet Blazer
Dayton 30' pedestal fan will run for an hour or so, seems to run hot.. there is slight burning smell. then fan makes little noise and shuts down.
Whats happening is that your fan is overheating (usually due to a loss of lubrication in the bearings), and the motor's thermal cutoff is kicking in (due to overtemperature), and shutting down the motor.
This thermal cutoff circuit is installed in consumer motors to prevent fires.
You have two solutions:
(1) disassemble your nice 30" pedestal fan (I've done this a few times - any handy guy/gal can do it),
and lubricate (with automotive bearing grease ($3 at any auto parts store), or 3-in-1 oil for those spots that won't take bearing grease) the bearings, and
reassemble. Re-lubricate on a regular schedule to prevent recurrence.
(2) buy a new one. Give your old fan to the kid on the block who thinks he/she can fix anything &
tell him/her it just needs to be lubricated.
May 13, 2011 | Dayton (2C373) Fan
We have a tempstar down draft furnace. 2 years ago the heat exchangers where replace because we were told they were cracked. This year the downdraft motor was makikg a lot of noise & we were told the...
Sounds like the low limit or high limit is out these control the fan motor.They are usually set to kick on around 150 degrees and set to go off around 95 to 100 degrees. Over heating does happen with cracked heat exchangers and it can possibly take these two items out. Normally your furnace should run approximately five minutes or a little less then your fan motor comes on and then for cooling down burners should drop and the fan motor should run again roughly five minutes or so then shut down. Times may vary as to your settings.
Dec 20, 2010 | Heating & Cooling
TRANE XR13 - Don't Want to Get Ripped on maintenance! Maintenance guy says that the gasket is leaking on the fan motor. There was very little oil that i could see. He also says the bearings are getting...
Do not let them change the motor as long as it is still running...I have seen them run like that for many years...yes, it could fail tomorrow or it could run for years...unless you absolutely need that unit to run with out failure... then keep the motor theway it is and when it does go it should only take a day to get the part and an hour to replace it... in fact any reoutable A/C company will have a motor in the truck...
heatman101
Apr 10, 2010 | Heating & Cooling
Dehumidifier runs but doesn't produce water
Your dehumidifier has a circulating fan that draws the room air over the coils. If there's no air movement out the front or back of the unit, the fan motor may be burned out or stuck, or the fan blade may be broken. If so, you need to replace the fan motor or the fan blade.
Sep 04, 2009 | Kenmore 5230 Dehumidifier
Fan has difficulty turning, buzzes
Hi
Tha model is a Maytag.
There are a few things to check here, and it's best always to use the proces of elimination.
These are the things you need to check:
1.MOTOR, DOWNDRAFT
2.BLOWER ASSEMBLY
3.SCROLL, BLOWER ASSY.
4.CORD, POWER (MOTOR)
as you mention before sometime run and sometimes do not run.
youll have to start by checking those items and make sure they are not damage or obstructed. I have some wiring diagrams for that model, if you would like for me to email them to you, please let me know.
I hope that will help you
Eddie Rentas
Tupper Lake NY
Jun 22, 2008 | Jenn-Air JED8430 Electric Cooktop
Kenmore 59940 Kitchen Hood Logo
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
