Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
AKAI PT5598HD won't turn on
I think my 4 year old daughter did a number on my TV while I was out of the room. Possibly pressed multiple buttons on the front of the TV.
The TV wont switch on. When Power button is pressed, the red timer light flashes about 5 times... then stays lit.
On a few tries, I could hear a quick sound in the speakers.
Any advice?
thanks
    Genius:
  • 2,920 Answers
Take it to a repair shop and have then look at it. it may or may not be worth the cost of the repair. i dont know what the parts and labor would be on it
Posted on Nov 17, 2008
My Akai TV Model number PT5598HD shows two of everything, how do I fix this?
U can't.Ur convergence is dead.Try website Tv repair World.com to buy a Convergence board to replaced.Well solved the convergence problems.The Samsung/Akai use the same convergence board.
Feb 15, 2010 | Akai PT5598HD 55" Rear Projection...
TV went out and will not come back on. Power light shows red but no sound or picture. It's about 4-5 years old.
I have a akai tv, the tv went out but won't come back on. i'm still getting a red light but the tv just beep when I press the power button.
Sep 18, 2009 | Akai PT4799HD Rear Projection Television
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
Akai 55
I used" Silerado 1st" solution. I have an Akai pt5598hdix/sms.
I had ghosting.Like 3 colors side by side.
Silerado said with TV off press "mute,1,8,2" then TV on.
I didn't see anything like a menu.He warned to write down any setting you saw before you change anything.But for me nothing came up. So as he said the next step try with TV "on" press "Mute,1,8,3" this is another set of adjustments for finer detail. I lined/overlapped all the lines up or down or side to side useing the channel and the volume buttons and then held the enter button down until the TV flashed 3 times.Then I shut it off and when I turned it back on It was perfect.
Thomas Fitzgibbon
Mar 23, 2008 | Akai PT5598HD 55" Rear Projection...
Pt5598hd convergence
I purchased mine about 5 months ago. Ive been researching and playing around with the remote. This will help you on the way. With the set off, press "Mute", 1, 8, 2 then turn the tv on. This will bring up the main settings, dont change any values on any page, unless you write the origonal values down first, because the total reset doesnt return everything to a "factory" preset. Scroll down to reset and press the enter key. I havent come across any owners or service manuals, and support is slim to none. I wrote a review for the same model on a wal-mart site I believe, and it explains adjustments in more detail. If you want to try to figure out the buttons for yourself, while the tv is on, press "Mute 1, 8, 3" this is another set of adjustments for finer detail. If you change an adjustment here and your not sure, just press the exit button. To save your adjustments in the convergence mode, press and hold the enter button, it should flash a few times and center itself on the screen. If you make a mistake in this mode, the total reset I mentioned first should get you back on track. If you find anything out or have a question, feel free to write me at Silverado1st@aol.com This is a nice TV, wonder why they stopped making them.
Jan 12, 2008 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
WOn't turn On
I talked to an Akai certified tech who told me the problem is a bad convergence module. The part alone is $400. Fortunately, I purchased mine from Costco 3 years ago. Costco has a 100% guarantee policy that I was not aware of. I called them asking if I had an extended warrenty and they gave me the full purchase price as a refund ! If any Costco purchasers are experiencing this problem and you purchased the TV prior to March 2007 (when Costco changed their policy), you may be able to take it back and get the full amount you paid for it. I turned around and purchased a new, larger Panasonic for under $150 more. It has a 5 year warrenty.
The Akai service number (to reach a certified repair place) is 1-800-726-4405. The Akai people are very good and can direct you to options. For those near Pittsburgh PA, Contact Rosewood Audio in New Castle 724 654-3023.
KW Pittsburgh
Dec 24, 2007 | Akai PT5598HD 55" Rear Projection...
Describe your Akai PT5598HD 55 in.
looks like you have a convergance problem akai is made from samsung
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD
Picture moved up and to the right
I know this is an old post, but it was never replied to and I just joined the site. Does the image only show the shift when on the DVD input? It is possible that the DVD player is the one shifting the image and not the TV. Try another device on that input and see if it goes away. Kenneth
Dec 18, 2006 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
