Question about Sony WEGA KE-50XS910 50 in. HDTV-Ready Plasma Television
Problem with Sony WEGA KE-50MR1
Hi, I was watching TV and a black vertical line (thick) appears. It happened last Friday. The serial number is 02200355 and tuner serial number is 04004784. Thank you for a quick answer please.
  • ANNY MARIN Nov 22, 2006
    I forgot the picture sorry. attached.
SOURCE:
techman
  • 3130 Answers
SOURCE: Thin Black lines going down my screen, sony Wega Ke-42TS2
These sets are common for bad connections on the ribbon cables connecting the screen to the drive printed circuit board. Or the drive circuit could have a bad drive scan IC. I doubt that but possible. Your going to need to call an AUTHORIZED sony repair servicer to trouble shoot this for you cause any other shop may not have a clue of this problem. Good Luck
Posted on Aug 09, 2006
  • 197 Answers
SOURCE: Sony Grand wega KDF-E50A10
bad lamp
Posted on Jun 07, 2009
vinnyq
  • 157 Answers
SOURCE: Hello! I have a problem with my kdf-e50a10 sony
This is caused by a failure of the optical block of your TV. The only way to fix the issue is to replace the whole optical block which is very expensive ($1000+) and time consuming (need to take whole TV apart to replace the part).
The optical block in your model had inherent issues and there is currently a class action lawsuit pending against Sony for this issue. Up to date information reguarding the lawsuit can be found here: http://www.sonya20tvclassaction.com/main/home.sfx
Posted on Oct 07, 2009
Testimonial: "Very Helpful, Thank you so much!"
leusnerdus
  • 54 Answers
SOURCE: Thick vertical lines
Hi. I am sorry to tell you that your LCD screen has finished its usefull lifetime. This is a typical pixel-line problem. This problem usually can not be fixed, It is necessary to replace the LCD panel. Though sometimes some lines disappear when you do some pressure round the egde where starts the line. To replace the LCD panel is usually as expensive as 80% of the Total price of the Device.
Posted on Apr 20, 2010
toolkits
  • 1099 Answers
SOURCE: Vertical line
Most probably the vertical deflection amplifier is failing. The most common part that fails is the vertical output transistor.
The set is too old to find documentation on part numbers and descriptions. Probably the part is no longer available and you will need the assistance of someone who can help you find an equivalent transistor that will do the job.
Of course, without testing we cannot be certain the failure is the output transistor. It could be from something else such as the voltage regulator that feeds the dc line to the vertical section. Could be the vertical synchronous level that goes too low to trigger the vertical sweep generator.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals
Good luck.
Posted on Jun 01, 2010
Black vertical lines (watching DVD); blank but lit screen (watching TV)
After 10+ years of service, it is a likely candidate for replacement.
Mar 21, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
I need a replacementnbase stand for a sony wega 42" plasma tv
Contact Sony with the model number to see if available or not, other than that Google the model number with base to see what comes up, last resort might be to look on EBAY.
Dec 10, 2012 | Sony WEGA KE-50XBR900 50 in. HDTV-Ready...
I have a Sony Wega KLV-30HRS3. It powers up ok, but the only thing that comes up is a multitude of coloured vertical lines. The built in graphics still work, ie the Menu page and the channel number in...
Hi there are a few things that could be bad on this TV. the first thing I would check is the T-con board if that's not the problem then the signal board and last the screen itself. If you are planing on doing it yourself you can get parts from www.interliquidparts.com
Jun 02, 2011 | Sony WEGA KLV-30XBR900 30 in. HDTV-Ready...
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Blue Vertical Lines on the screen
It means the optical block is going bad. Contact Sony support. They will sometimes warranty these even after the 1yr warrany has expired. Have your model and serial numbers handy.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony WEGA KE-37XS910
This TV has a very expensive panel... we are talking $3000 core charge alone! It comes complete with all the lower buffer boards (which from the sound of it, you are having a problem with). Individual boards for this defect are not available on repair parts list I know of. A panel is what you need, PN: 9-885-063-33
Aug 17, 2008 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Aug 08, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony WEGA KE-50XS910 50 in. HDTV-Ready Plasma Television Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
