Question about HP Computers & Internet
When I put the computer to "sleep" it decides to come back on by itself. This happens frequently, but not all the time. What could be causing it to do this? Also, if I shut the computer down, completely, on occaion, when I try to log on the the interent, it won't let me and if I try to shut down to try again, it locks me in and I have to shut the computer down by pushing the on/off button, rather than using the icons to shut down. Then, of course I get the message that I shut down wrong. What casues this to happen? Is it a Vista problem? I never had this problem on my old computer which had XP.
  • harjolupeg Nov 15, 2008
    The pc is a HP Pavilion Media Center m8400f and the vista is Windows Vista Home Premium
  • Shaun Plencner
    Shaun Plencner May 11, 2010
    what verison of vista and what type of pc
    Looking to Help U Shaun
  • 395 Answers
Sleep on Vista is a combination of Standby and Hibernate. First it will go into Standby and then later if a laptop it will go into Hibernate. Any movement of mouse or keyboard may cause it to wake up.
Some computers will wake on Lan. If you have ethernet connected this may be the cause. You can turn this off by using Device Manager - Hardware - Select ethernet adapter - driver - Advanced - look for Wake on Lan and Pattern Matching and disable this.
ALso check your BIOS settings and disable all Wake on XXX settings.
Posted on Nov 16, 2008
Proper Procedure for Putting Computer to Sleep
Change your sleep settings in the Control Panel under Power Options. You can set it to never go to sleep or have it to go to sleep after 2 hours. There will be settings to control when the monitor shuts off, when the hard drive shuts off, etc.
Apr 23, 2012 | Compaq Hewlett Packard Presario SR5110NX ...
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
My mac computer keeps putting itself to sleep
It may be that the computer is overheating. Are you using the computer on a bed or other soft surface that might be preventing the computer from cooling properly?
Jan 21, 2012 | Computers & Internet
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
My dell C610 Screen does not come back on when i reopen the lid. I turn the computer on use it then close the lid for about a min then reopen it and the screen just stays off but the computer itself is...
Known issue. The windows default settings for power saving mode tell the computer to switch it off (sleep) when the lid is closed. The sleep mode doesn't turn completely the computer, just the visualization devices (mainly screen, also some other components not required for the computer).
What I would advise you to do after restarting the computer (press on the power button for a very long time, until you cannot hear it working), is to change the power settings.
go to control panel, choose "power options", then see if you have "choose what closing the lid does". If it's not there (not all laptops show this option), choose "change when the computer sleeps", then change " put the computer to sleep" to "never".
That should do it. if you have any questions feel free to ask me.
Dec 07, 2009 | Dell Latitude C610 Notebook
Computer won't use sleep mode anymore
Go to Advance Power Settings.
Set hard drive to turn off a minute or 2 before sleep.
Set Hybrid and Hibernate modes to "Off"
Under USB settings select "Disable"
Under Multimedia select "Allow ....." also setup your screen to turn off ( pick how long monitor will stay on. you can also try going into the bios and setting it to default. save and reboot. let me know if this helps.
Nov 13, 2009 | HP Pavilion S3420F Slimline Desktop PC
I am not a computer professional, I am just trying to figure out what the heck has happened to my computer. I have a HP Pavilion Slimline s3420f PC and it is running Vista on it. I have always just put my...
Sleep is more commonly known as Hibernation with Vista.
Sometimes certain updates or freshly installed service packs can mess with your settings, or sometimes disable the feature altogether.
Microsoft have released a fix for just this problem.
Go here to Microsoft (link below) read down the page until you see Fix this problem, click on that and then click on Run when prompted.
You should get a message saying that the problem is fixed.
Restart your computer and set your Hibernation settings.
Hope this helps and good luck
Turn it on, then wait, u will hear the computer turning itself on and off, but nothing is showing on the screen. so make it turn on and off, 3 time.( such as hearing the computer turned off, so that one,THEN IT TURNS ITSELF ON AGAIN, next time it turns off, that count as 2, and so on). on the third shut off then u press and hold the off button, to force it to shut down, then wait. about 5-10min., or less then 5. after then u turn the computer should be on by now. if not try it again. if it happens again try one more time, if it happens again. then there something really wrong with your computer.
Jun 15, 2009 | Nikon COOLPIX L20 Digital Camera
Tv switches off after 5 mins
There might be three or more reasons for this:
1) The sleep timer may be on causing the TV to turn off after a preset time.
2) If sleep timer is on and no signal from the remote is received for a preset time (Samsung: 15 minutes) the tv will turn itself off.
3) The TV may have been turned on automaticaly with "On Timer". If so, and no signal is received for a preset time (Samsung: 3 hours) the tv will turn itself off.
4) A fan is not working or a vent is blocked causing the TV to overheat and turn off.
For 1) thru 3), go to the "setup" menu and make sure "sleep timer" and "On Timer" are turned off.
May 09, 2009 | Televison & Video
Sleep vs Shut down
It depends on how long computer is being used in a day.
for general use
you can shutdown your computer once in 2 days but i highly recommend not to put in sleep mode and betting putting in hibernate mode instead of sleep mode.
note: most of simple issues are resolved by restarting PC so you can guess now how important is to shut down computer.
Good luck,
Mar 25, 2009 | Apple 24" iMac Desktop
Computers & Internet Logo
133 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
