Question about RCA F32650 32" TV
RCA F32650 won't power up/ high pitched squeel
We purchased this set new in January 2004 and have had no problems with it until last night. It was working fine, I shut it off, and about 4 hours later I tried to turn it back on and it wouldn't power up. At this point the power LED next to the button would just blink 3 times slowly (about 1 - 2 seconds on, then 1 - 2 seconds off) and then just stay off. I tried unplugging it for about 10 minutes, but still had the same symptom. This morning we moved it from the room it was in to an area where I could work around it, and upon plugging it in there it now just produces a high pitched squeel with no reaction to the power button (or any other button) whatsoever. I removed the back cover and found the usual dust and cobwebs which I cleaned with board cleaner, however it still just squeels when plugged in. Is this a common failure for these, and if so how expensive is the repair normally? I saw some very negative postings about late model RCA TVs on the web tonight.. should we just walk away from this set? Any help would be appreciated! Thanks!
  • David Schaffer Dec 07, 2006
    Thanks for your response techman. I have enough electronic experience to know that I have no desire to poke around in the back of a tube television. I can read and follow schematics, but have no desire to attempt repairing this TV myself. I guess what I'm primarily wondering is is it worth sending this set to a repair shop? As stated in my original post, I've read a lot of negative posts about late model RCA TV's (those manufactured by Thomson out of Ontario) and wanted to have an honest opinion on whether it would be worth investing repair cash in this set?? The negative feedback I read was already enough for me to pass on the "Black Friday" Walmart special on the RCA 52" HDTV they had for $400... not worth it if it's going to go bad like this relatively shortly out of warranty. Should I send it to a shop, or in your honest opinion should I just scrap it and buy a different brand? If so, which brands are most reliable presently? Thanks for all your assistance! :)
  • David Schaffer Dec 10, 2006
    I take it it's not worth fixing this one then. I didn't go for the Walmart special because I had seen posts on the net from people who purchased the RCA HDTV flatscreens and had them stop working within the first 3 months, and then had MASSIVE problems getting them fixed in a timely manner (one person waited over 3 months before their set was finally fixed!!!) I have no time to deal with inferior stuff from a company that appears to ignore their product's issues like that. What's crazy about all of this is that all of our other sets (4 of them) are either Phillips or no name sets from Walmart, and the youngest of those is 5 years (the oldest one is 13 years), and they are all still working fine and cost half the money or less than this RCA did. It's a shame really.. RCA used to be THE name in TV's. What are good bets on larger screened TV's out there presently?? Any educated opinions on that?? :)
  • 65 Answers
Ditto this tv is known to have bad flybacks crts and hots as much as i dislike rca products the wally world deal would be worth the 400 bucks 1year and 1 year 2 on the tubes even if you watched it for 2 years you could put a garbage sticker on the projo for 400 dollars the scenium tvs were also known for bad crts
Posted on Dec 09, 2006
    President:
  • 3,130 Answers
HARRomeo, the horizontal output transistor will usually make the set have a high pitched sound, as that is the power supply being loaded down, if you habe any solid state repair experience, thats where you should start. As you should take out the transistor and measure it with an ohm meter and see if it is shorted. There are several reasons the transistor will short. Most of the time , it is the high voltage transformer also know as the flyback transformer. Also a drive problem could cause this to shprt also. In some cases the power supply itself could have a bad regulator, or a bad capacitor in the circcuit. Bottom line if you have the experience, you will need to get a schematic, and trouble shoot the sweep circuits first. if you do not have any solid state repair experienc3, Please play it safe and seek out the help of a trained repair person. Good Luck Please dont forget to rate this thread.
Posted on Dec 06, 2006
SOURCE:
My 2004 range rover is squeeling when you unlock the doors
Sounds like a solenoid going bad in the power lock control.
May 05, 2012 | Cars & Trucks
Rca 32 rca 32
The repair of this problem will be near to or exceed the cost to replace it with a new flat screen. With TV prices at an all time low due to slack demand it is not cost conscious to repair it.
Jan 24, 2012 | RCA F32650 32" TV
The TV will bring to turn on but then it sounds like it loses power and makes a high pitch noise and powers off, no picture ever comes on the TV, the screen stays black the whole time. The TV is a RCA...
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
Jun 02, 2010 | RCA F32650 32" TV
Turned it off last night was working great, this morning we cannot get any power at all, everything else is working around the same plugin
These sets have quit a complicated power supply and that is usually how they go. Everything is all good at turn off and then stop at next turn on. It could also be a horizontal/high voltage issue. It is hard to say as there are many probable causes. Thanks
Nov 01, 2009 | RCA F32650 32" TV
10-year-old 32" RCA PIP TV just blinked off one morning after about 30 minutes. It makes a continuous high pitch sound, and the on/off switch is completely unresponsive. I assume this is a picture tube and...
It's not the picture tube(especially if image was good b4 it went dead). The high pitch noise is the power supply whinning because it's shorted or overloaded. I just fixed one of these sets - replaced the horiz. o/p transistor and flyback estimate around $120.00-$160.00
Oct 24, 2009 | RCA F32650 32" TV
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
F32560 Rca Chirping
Replace IHVT aka flyback xformer part#257805 and horiz o/p xistor part # 237470.
Nov 30, 2006 | RCA F32650 32" TV
RCA F32650 32" TV Logo
120 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
