Computers & Internet Logo
angel Posted on Apr 19, 2012
My computer starts but duse not boot up or beep
Anonymous
Level 1:
New Friend:
  • Contributor 99 Answers
  • Posted on Apr 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
99
Questions
0
Helped
15543
Points
43
There are many things that could be causing this problem... Follow these steps to narrow down the possibilities:
1) Unplug everything from the motherboard except the 2 from the power supply and remove the RAM
2)Swap the power supply with a known working one
3)Swap CPU with a known working one
4)Your motherboard is faulty
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 • Computers & Internet
tip
Computer beeps
If you try to power on your computer and nothing happens but a bunch of beeps there is something you can do. The beeps actually mean something. To make sure you can hear the beeps check in the bios options. If there is an option for a silent boot you won't hear any beeps. If you hear one beep every time your computer starts then you don't have to worry about this.
If you want to check this setting refer to my other tip on how to enter bios and change boot settings.
If you try to boot your computer and nothing shows up on your monitor do these steps first.
1-Check all your cables in the back of the computer.
2-check your power source and power cord to the monitor
3-try another monitor if possible
4-If on a power bar try to turn off the power bar and reset the breaker
If you try to boot your computer and nothing happens and you hear beeps look at this website. The beeps you hear are actually telling you what is wrong. Look at the website by clocking on the link below and click on the computer beep codes link. If you want to scroll down past the link it will show you bios codes to enter the bios in your computer
http://www.michaelstevenstech.com/bios_manufacturer.htm
Computer starts but duse not boot or make any beeping sound
When i boot up the computer it starts beeping immediately, otherwise boots just fine
The beeps are part of the boot sequence, more normally called the post report. The beeps length and number usually indicate a problem.
Check with the abit website, you need the post sequence for your motherboard.
Usually, with a post report, you get a single beep which means everything is tickety boo.
Than you in advance for any and all help pertaing to my issue. Problem: 3-4yr old HP laptop. Did have Win XPsp2 on it. HDD went bad. Used Barts PE to create bootable cd-rom with half working Win XP, but...
Why do it the hard way? If your HDD is bad, most probably the system files are corrupted too and getting/making a bootable CD from the HDD files is just wasting your effort. If you laptop CD/DVD drive is still good, then use the options below: -
1. Go to any torrents site download "hp oem xp" disc from the site & burn the bootable image to a CDR.
2. Go the the Hp support Site & download the XP drivers for your Laptop model.
3. Then you can do a new installations on your Laptop.
Hope it helps.
G31TM-P21 normally boots with series of beeps. Now will not boot properly from CD start sequence (for reinstalling op system) and gives a short beep about every 5 seconds. No information found on MSI...
According to the sequence of beeps your getting from your computer, ther is a possibility that there is a problem with the memory module or RAM on your computer. Try reseating the memory then try to boot up again.
Cheers!!
1helpful
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Switch on!!!!
PLUG IN CHARGER AND SEE IF IT STARTS TO CHARGE IF IT DUSE NOT GET NEW CHARGER IF IT DUSE START TO CHARGE TRY TO TURN ON AS IT IS CHAGRIN IT SHOULD COM ON MAKE SHORE THAT THE BATTERY IS HOLDING A CHARGE
2answers
Wd500aaks driver
All you have to do insert any operating system bootable disk and then boot in CD/DVD rom and partition HDD and format and then install the operaitng system.
Here a guide on installing windows xp operating sytem :
http://www.geekgirls.com/windowsxp_install.htm
hope this help
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
