Tappan TGF320 Gas Kitchen Range Logo
Anonymous Posted on Nov 22, 2006
Oven not always working
My tappan gas range has an oven that works occasionally. sometimes it won't even come on-it just smells like gas-any ideas? it works sometimes thanks
  • 1 more comment
  • Anonymous Dec 05, 2006
    "Rotu"-wish I would have gave you 5 marks instead of 4,because you were right! Thanks buddyrhonda
  • jimmymo Nov 20, 2007
    When I try to light my oven it blows the circuit-breaker box.
  • Anonymous Jun 29, 2008
    My tappan oven Model # TGF317BWB comes on sometimes. Most times it just warms up. the pilot is comes but will not heat up.
Douglas Henry
Level 2:
  • Expert 175 Answers
  • Posted on Nov 23, 2006
Douglas Henry
Expert
Level 2:
Answers
175
Questions
0
Helped
182200
Points
375
MOre than likely your igniter is getting weak. If it doesnt pull enough amperage. it shouldnt let gas into the oven. If it is letting in gas and not igniting, I would suggest a new igniter and a new safety valve. Hope this helps!
1helpful
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
3helpful
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Tappan gas range tgf355 error code f1; what does it mean?
Where can I find the manual of the parts of the rear box of a Galloper 4X4 year 2001
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
4helpful
2answers
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 • Ovens
Top Tappan Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
