Question about Air Tools & Compressors
Oiling my nail gun
I have a campbell hausfeld nail gun but no manual, i'm not sure where to oil it....looking for some help!
  • Anonymous Mar 22, 2014
    need manual for campbell hausfeld air nailer
  • Anonymous Mar 29, 2014
    need a manual lost mine
    Problem Solver:
  • 18 Answers
You simply put a couple of drops of pneumatic oil in the air chuck on the handle every time you're going to use it, and then hook up the hose.
Posted on Nov 15, 2008
Does a 2/3 HP .40GPM Campbell Hausfeld Airless Paint Sprayer require any kind of oil if so what kind and how much
airless sprayers have a pump that pumps the paint through a jet at pressure . there is no oil and it is vital that when finished that the pump be spotless after cleaning
Nov 12, 2015 | Campbell Hausfeld Air Tools & Compressors
Air gun "clicks"
Sound like o rings are bad. If you don't know how to rebuild it then have a tool repair shop rebuild it.
Jul 27, 2013 | Campbell Hausfeld 2" 18GA Brad Nailer
Looking for campbell hausfeld airless spray gun ps220a 2/3 hp operators manual Please!
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support" tab select 'Manuals/Parts Lists. Do a search for your model number and you'll be presented with the manuals and parts lists for that line of paint sprayers.
Feb 28, 2013 | Campbell Hausfeld Airless Spray Guns &...
Gun fires, leaves good indentation, no nail. WCE working properly, took head apart to look for jam but nothing in there and am using compatible nails. Also oiled it but no luck. Was working fine doing...
Remove nails and use thin tool to push driver all the way up to top of cylinder. If the gun fires one nail then skips, the driver is not returning to top of cylinder. If no nails fire, then nails are not feeding into proper position. Driver must return to top to allow nails to feed into position. Most common problems are bent driver, worn piston oring and bad batch of nails(head too large). Good luck
Jan 14, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
Two nails at a time and one of them only goes in one quarter of an inch.
Campbell hausfeld makes a 21 and 34 degree angle nail gun. The most common mistake is the wrong nails are being used. Some after market nails will not work correctly in some guns. Check to see if the gun accepts wire welded or paper clip nails. Check the angle required. Also be sure the gun is oiled if it is not an oil- less gun. hope this helps.
Jan 11, 2010 | Campbell Hausfeld Air Tools & Compressors
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Driver wont retract
check to make sure the head bolts are tight on the top, if they are it probably needs a rebuild kit from campbell housfield includes orings for the piston, gaskets ect. and instructions
Jan 18, 2009 | Campbell Hausfeld MP292000AV 1/4 Inch...
Air Tools & Compressors Logo
198 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
