Question about Lands Phones
The bluetooth on my phone will sync and pair but won't connect.
  • turtlenrs1 Nov 15, 2008
    my cell phone its a motorola krzr. It used to connect with no problem, it just stopped wanting to connect for some reason. Its paired and all, but when I tell it to connect it will just say connecting and never connect. . .I let it sit for over an hour to see if it would finally connect but it won't.
  • debbiecallan May 11, 2010
    which phone and what are you trying to pair it too??
  • 3 Answers
Try taking the battery out of your phone and put it back in and try again.....
Posted on Nov 15, 2008
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Bluetooth won.t connect
You may need to pair the bluetooth again as it may have lost its pairing id sync.
Delete the pairing if it exists and start from the beginning.
Apr 18, 2014 | ASUS MeMO Pad HD 7
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
U430 will not work with ford sync
I have the same problem. Trouble pairing but finally I got the SYNC to find my U430 and paired but the SYNC never connects with the phone.
Sep 17, 2010 | Samsung Cell Phones
How do I bluetooth pair my i9 phone with my Ford SYNC
On your Ford Sync board, press the phone button. It will start to search for already paired devices. If none is found, press the arrow buttons until you find 'Add Bluetooth Device'. Then, press OK. You'll see it will generante a PIN. Now, make your phone's bluetooth application look for new devices. After a while, the Ford Sync device will appear on the phone screen. Select it, and make the the bluetooth application proceed. When a PIN (or pairing code, or passkey) is requested, enter the PIN generated by the Ford Sync device.
Hope it works for you.
Regards, Carlos
May 20, 2010 | Cell Phones
My bb 8310 AT&T device won't pair with a headset or with my ford fusion
Make sure you have the correct password for your phone. Also look in your fusion manual as to the correct steps needed.
  • Press the Power Button. // This is on a 2010 Ford Fusion.
  • Then you hit the Phone Button.
  • It should say “No Phone Paired” that means that no phone has been paired with this.
You now have a choice of options:
  1. Add Bluetooth device
  2. Connect Bluetooth device
  3. Set Primary Phone
  4. Set Bluetooth On/Off
  5. Delete Device
  6. Delete all Devices
You want to choose Add Bluetooth Device, press OK
  • Then on your mobile, turn your Bluetooth On.
  • Setup Bluetooth – Search
  • Now it’s searching for it, when that gets full, Click Sync.
  • Then you’ll want to enter the PIN number that’s on the screen.
  • Say YES to connect to Sync.
  • Now screen on dash will say your mobile phone
Mar 26, 2010 | RIM BlackBerry Curve 8310 Smartphone
G2 bluetooth will not sync with any other phone?
look at BT manual to turn on visibility of unit then when phone finds it u need to set up a 4 digit security code for the pair to connect
Aug 13, 2009 | Cell Phones
Syncing blooetooth
Headsets don't be synchronised, as syncing means to update to devices with each other.
Bluetooth headsets are paired. Pairing means that both Bluetooth devices recognize each other and trust each other, so you do not need to provide any type of confirmation.
So, follow the phone's manual to see how to switch on the Bluetooth and make it visible. Now, there must be an option like make a new paired device. Consult your manual for this. The phone will search for a deivce and they will be paired.
You can even pair a PC and phone, phone and phone and every kind of Bluetooth enabled devices.
Jan 30, 2009 | Motorola Mobility H700 Wireless Headset
Palm TX, Dell 6300 Laptop, can see each other through Bluetooth but will not connect. Want to connect to sync clocks.
Have you checked your hotsync settings and bluetooth settings to make sure that you are using bluetooth sync and not the serial connect. Palm devices can also share LAN/Internet over bluetooth.
Jul 18, 2008 | Apple iPhone 3G
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
