Question about ASUS P4P800 SE (890552603657) Motherboard
Dvd writter problem in asus motherboard
My system Amd processer and asus main board now i am newly connected lg dvd writter then system start boof failers and put any disk totally system hanged restart the system normalliy working when we put the cd or dvd not supported solution please ...
    Sergeant:
  • 207 Answers
We likely have a "Jumper" issue here. On the back of the Drive right next to the Data cable there should be a group of jumper pins along with a general diagram or the jumper settings.
The diagram will likely be stamped in the metal next to the jumper group, or on the label.
The settings we are concerned with are CS (Cable Select), M (Master) and S (Slave)
First one I want you to try is CS move the jumper block to connect the pins for CS (If there is another drive on that cable, its jumper should be set to CS as well)
Now try to boot up again. If it works, you are good to go.
If not try the M setting on this drive. If it shares the cable the OTHER drive should be set to S this time.
Now try again. If still no luck reverse which is M and which is S
and try once more.
If ALL of these options fail, please post back here and we will try to assist you further.
Thanks
Dave
Posted on Nov 15, 2008
I have a k8m 800 mother board with amd processor 1gb ram 500gb sata and LG sata dvd writer, my system is not working it is restarting. it is working only under safe mode. attemting to reinstall xp, first...
I would suggest that after windows copy all the driver in to your hard drive, instead of choosing a new or fresh installation you choose the letter "R" for and then 1 for the directory. Windows will attempt to recondition or reinstalled missing system files.
Sep 17, 2011 | ASUS K8V-MX Motherboard
Hi. I get a blue screen with bad_pool_caller error, xp pro starts and stops and then blue screen and reboot forever. Is the motherboard (ASUS M2N68-AM SE2) in default. AMD PHENOM QUAD CORE CPU temperature...
Dear mariolama
It can be due to error in any newly installed hardware or software.
Most probably due to RAM. Check your RAM is perfect or not in other system. Or clean it and restart the system and check.
Reply me the status
Thank you for using FIXYA
Mar 14, 2011 | ASUS M2N68-AM SE2 Motherboard
Problem of dvd/cd writter
check the IDE/SATA cable,if its connected,now u must to become sure from lens.maybe it need to cleaning.therfure,if after cleaning this problem still apear,so u must change the board or somethings in it by testing
Jul 07, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
I have asus motherboard with amd processor , i tried to attach multipal harddisks with it but it does not work , what i have to do? for proper functioning?
you need to make one hard disk master and other as slave ...for this you have to change jumper setting which you can find near to the IDE cable ..
Jun 28, 2009 | AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD...
Cannot get new ati radeon 4350 graphics card to work on my asus motherboard
A couple of suggestions, in case you over looked them.
1) Get into BIOS and make sure the on board is disabled there. I've have trouble before when I missed it.
2) If the old one is showing on your Device Manager, Disable it but dont uninstall it. Then remove any drivers for it.
Apr 29, 2009 | ASUS M2N-MX Motherboard
Asus P5Q Upgrade disk error
take the cabel from the dvd out...and try to start igen.
Or try to fixboot with your windows cd...
Apr 11, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Drivers for asus 845 motherboard with amd athlon xp processers
You can download the driver of your motherboard but you have to specify your system model number and then the operating system .
Follow this link : http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 22, 2009 | ASUS P4PE-L 845PE Motherboard
Can i replace the processor without changing the mother board ? because i am facing internet speed problem,
I am HCL Branded Computer of AMD Athlon XP 2000+ 1.67GHz RAM of 128MB with a via motherboard D___ and i newly install 80 GB Hard Disk, and a DVD LG Writer.
MY Question is__?
  1. I want to updated my Processor without unistalling mother board.
  2. my internet speed is very slow? pls tell me how to slove this problem.
I will be thankfull if your team will help me to slove my PC Problem.
Aug 24, 2008 | AMD Athlon XP 2000+, 1.67 GHz Retail...
ASUS P4P800 SE (890552603657) Motherboard Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
