Question about Panasonic SL-SX320 Personal CD Player
My CD player keeps flashing (F15) when I try to play a disc.
The first track will start to play, but a few seconds after that it starts to continuously skip and the display starts blinking (F15). When I try skipping ahead to the next track it wont play it at all and the display continues to flash (F15). I've looked through the manual and can't find anything in there about it. What does the flashing (F15) mean, is it fixable?
  • Anonymous Mar 27, 2014
    Show's last second of song before skipping to next track
    Problem Solver:
  • 6 Answers
It means that the laser/motor module is disconnected. Open the player and locate the connection band of the module. It should be orange, about 1 cm wide and it comes out from under it. Push it HARD into it\'s socket. Make sure you don\'t leave sweat or grease on the electronic and test it. I hope it works for you!
Posted on Dec 05, 2006
    New Friend:
My CD player keeps flashing (F15) when I try to pl - a58b8968-f1c2-4ca9-9f92-fd815d18446e.jpg
In 2001, I bought a Panasonic sl-ct590 cd player, six years after the failure: The display shows "F15", each time you put into the cd will hear "clacked" bald action sound for about 15 seconds after the normal playback, but the turn off or failure of the above will open the lid, and a lot of trouble, has not been repaired, he had to attempt to disassemble, but not smoothly apart, then gave up repair.
This afternoon, I saw a netizen dismantling this type of cd drive, a detailed dismantling order, I tried again to disassemble, smooth apart, after the head bracket upside down, cleared laserhead rails (2 rails) at the tiny fibers, hair, dust, and then use an alcohol swab to clean, also coated with a lubricating grease, apply silicone grease, found the head bracket touch reset switch,To reset switch good contact, I pasted in the corresponding position of the bracket 2 layers 3M insulation tape, and then re-assemble all the parts, and put on the chewing gum battery and put it into cd "clacked" actually did not hear the annoying sound, and it is fast into the playing status, repeated the test several times, did not occur again "F15" fault code, that's great, repaired CD player, very happy!
Friends want to have the same problem also can try, I hope you can succeed!
Posted on May 18, 2013
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Cd not able to play last few tracks knocking sounds
CD Mechanism is possibly faulty. Sometimes won't track the outside of the disc properly. Try other CD's of about the same playing time, if more than 1 disc does it, the fault is usually the mechanism. (If the disc is a lot longer than the standard max CD length 0f 74 minutes, some players may have a problem with them. This was usually with older generation players, so may not be applicable here.)
Nov 26, 2013 | Cambridge Audio Azur 650C
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Cd player starts, but stops play by 2nd track
Sounds like tracking motor and/or gear problem!
Check for a small crack on the tracking gear.
Parts not avalible from Bose though, they'll only
fix as a "flat rate"!
Apr 12, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
Panasonic SL-SX320 Personal CD Player Logo
437 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
