Question about RCA P52771AT 52" Rear Projection Television
Model; P52750WK serial; 340486076
I hit the power button, power turns on for a moment and immediately powers off. followed by a series of blinks, from 'power' light.
  • sirkool Nov 18, 2008
    i have same problem
  • Anonymous Dec 31, 2008
    I have the same problem
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Posted on Aug 30, 2007
Power button: when turning on tv with power button, green light comes on, button clicks, screen starts to light up and then immediately turns off. Can't keep tv on! Help.
I was reading the troubleshooting guide and used your symptoms to find this information. In the following case, power off the monitor immediately and contact your dealer or authorized Service Center. The monitor turns off 5 seconds after powering on and then the POWER/STANDBY indicator blinks. It indicates that the power supply circuit, plasma display panel, temperature sensor, or one or more fans have been damaged. It is very common for these TVs to get filled up with dust. The dust covers and insulates internal components and cause them to over heat. I hope this helps. Good Luck.
Sep 24, 2018 | Televison & Video
I need a validation code fro quickbooks pro 2011. the Licen number1063-0575-1585-222. and Product number 019-147
i have a dell latitude E5520 laptop,having a power-cut issues,the moment you press the power button,the light comes on then goes off immediately,. when u plug in the charger,the charger light indicator turns on and also goes off immediately. i need help to solve it.
Thank you
Aug 01, 2017 | The Computers & Internet
7.5 amp fuse
check all the wiring make sure no corrosion or exposed wires other than that try replacing the button module
Jul 19, 2013 | Generac Guardian Electrical Supplies
Hibernate issue
Boot the computer into Safe Mode and try changing the Power Options.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
May 16, 2012 | Acer Aspire 4720 Notebook
Hp slimline s3000 goes immediately into sleep mode
Try booting into Safe Mode then go into the Control Panel and change the Power Options.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Once safe mode is up click Start/Control Panel and look for Power Options.
Apr 08, 2012 | Computers & Internet
My IMEI.353783046365270 X-plore versi 1.51 give me serial number please
  1. Check the back of the phone for a SIM card before proceeding. The following steps will not work on phones using a different system.
  2. Turn on your cell phone and let it sit for a moment to fully power up.
  3. Input star (*), pound (#), zero (0), six (6), pound (#) in that order, using your keypad. Wait a moment to see if anything happens. If it doesn't, press "Send." Certain phones require you to press send after the last pound button.
  4. Look for the number that appears on your cell phone screen. This fifteen digit code represents the serial number of your phone.
  5. Make a note of the serial number and keep it in a safe place until you need it.
Jan 31, 2011 | Nokia 6600
My ps3 is not reading my games
My ps3 didnt read my ps3 games..followed these instructions and it worked!!
http://boardsus.playstation.com/playstation/board/message?board.id=ps3updates&thread.id=52730
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to ONLY option 3 (restore)
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3
9. Follow on screen prompts
Thanks to Krazyfox
Apr 19, 2009 | Sony PlayStation® 3 (80GB) Console
Power Problems
You may have jarred a component loose inside. Open the side panel and carefully inspect the cable connections and circuit boards.
Check the memory sticks as well. Good luck!
Mar 13, 2009 | Gateway 310 Series (158920) PC Desktop
When I turn it on I get E01
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
Televison & Video Logo
225 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
