Question about iLO V27DMBX Television
Top part of screen is black
I have a 27" mts stereo tv w/digital tuner for about 2 yrs/ the picture is starting to disappear. meaning the top part of the screen has a blk box across the top,
  • s40sally Nov 17, 2008
    Thank you for your response. I agree with the latter buy a new tv thanks again!!!
    Scholar:
  • 146 Answers
A "black box" sounds like the close caption is turned on. Go into the menu and make sure it is off. If it is not close caption, you have a bad problem. If the top half of the picture is missing, this sound like a panel problem. The panel will need to be replaced. Panels are not cost effective to fix. Buy a new tv.
Posted on Nov 17, 2008
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
I have a black in the top right hand of my tv
msarnowski,
If you mean you have a black square in the top right hand of your picture, it sounds like the Picture in Picture feature is turned on and there is no signal to the tuner, which will show as a black square somewhere on the screen.
Open the menu and check the setting for the picture in picture feature. This could solve the problem.
Thanks for using FixYa and for the great rating!!
hardrocko
Aug 30, 2010 | Hitachi Televison & Video
We have a 27" MTS Stereo color TV. There are white horizontal lines at the top of the screen. We do have a DVR with Direct TV. How do we fix?
U can't.Only horizontal lines on the top parts of the tv screen or the lower parts of the picture screen.Or very light horizontal lines mix in with the tv screen pictures.The "CRT" the picture tube is slowly dying of old age.Quicker than they supose to.The late 90" these problems case show up alot more in standard tvs using CRT tube.Because the CRT and analog design about to be faze out of the market place.The glass molding and those radiation matrials,they used to make those "CRT" picture tube materials,not as good as before.
Aug 03, 2010 | Sansui Televison & Video
Audio missing on some stations
Solution in audio settings, choose MTS stereo. TV was set to something else.
May 28, 2009 | JVC AV-27D302 27" TV
I am not using cable or dish...what type of antenna should i use to get the most out of the digital conversion...and is the built in converter adequate or do i need converter box?
The specs for this TV shows it has ASTC and NTSC so you do not need a converter box.
Almost all the Digital channels are broadcasted in the UHF band.
When you scan in the channels the VHF numbers will still show but the actually signal will be in the UHF band.
Go to
WWW.TVFOOL.COM and enter your ZIPCODE to get the stations in your area.
MPN: IWT3206 Key Features Digital TV Standard: SDTV Diagonal Screen Size: 32 inch Display Capabilities Built-in Tuner: ATSC · NTSC Image Quality Comb Filter: 3DYC / 3D Digital Audio Features Audio Type: Stereo SAP / MTS Stereo: SAP / MTS Stereo Technical Features Sleep Timer: With Sleep Timer Connectors Rear Input Connectors: Composite x 1 · Audio (RCA) x 1 Front Input Connectors: Composite x 1 · Audio (RCA) x 1 Screen Text OSD Languages: English · French · Spanish Miscellaneous Product ID: 37594421 More Information Details: Big picture, small price. Enjoy watching your favorite, sports, programs and movies on this generously-sized 32" TV from ilo. The side stereo speakers help create a richer sound experience. Even more conveniently, the built-in digital (ATSC) tuner accesses digital content without the need for a separate set top box that takes up space. And since the screen delivers standard definition (SD) resolution.
Apr 05, 2009 | iLO IWT3206 TV
I want to know if my tv is digital ready.It is a ilo tv with a sdtv tuner,mts stereo.dolby digital,ccd. Will i have to buy a digital converter
SDTV does not mean hi def but it does often mean digital. dont know what model you have but if it can tune ATSC or the channels with the dot, like 10.1 or 8.3 then your good to go.
Aug 26, 2008 | Televison & Video
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Big black box at top of screen
If you mean that a black box appears on the screen, and you can still see the picture around the box, it means that your closed captions are on and set to TEXT. If this is the case, enter the menu, navigate to the closed captions page and set the captions to OFF. If you mean that the top of the picture has collapsed down, the vertical circuit has stopped working correctly and the set should be serviced by a qualified tech.
Sep 15, 2007 | Philips Magnavox 27MS343S 27" TV
Horizontal lines across the top 2 - 3" of the screen
Sounds like you have some capacitors that are needing to be changed in the vertical circuit. The cost I cannot quote but, it probably won;t be worth the cost as replacement TV's are much cheaper now. Zeniths and other brands for the longest time have used not controls inside the TV, they are technician adjustments through a service menu only.
Apr 19, 2007 | Zenith C27A24T 27" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
iLO V27DMBX Television Logo
95 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
