Can't configure my laptop to this new router. It asks for a password, which I did not need to use on my MAC when I installed it. Where do I find the "password".
  • 2 more comments
  • drjanb Nov 15, 2008
    I tried this solution. I STILL don't know which "code" to use- I've tried them all.
    "Inside the Router" to get the password. On the back of my router I have 4 code numbers. Which one do I use?
    When I was installing this router (new as of last week) I was never asked for a password.
    Thank You for your assistance. I still did not solve the problem. Can I call anyone regarding this issue?
    I feel frustrated because I just bought the router and modem (my new puppy ate through the wires of my old one), I have been unable to connect my laptop to the internet and I have just spent another $10 trying to do so - next step is going back to Best Buy for assistance.
    I do appreciate what you have attempted to do on-line.
  • drjanb Nov 16, 2008
    I tried your suggestion and it still didn't work.  I have the Geek Squad coming over on Monday.  The reason I contacted your web site was due to my searching "DYNEX.com" and your site came up.  I thought you were the official site for this router.
    Thank you for your assistance.
    President:
  • 1,257 Answers
Here is the solution for you
http://www.phenoelit-us.org/dpl/dpl.html
http://www.routerpasswords.com/index.asp
You will see a drop box .so select the router you are using and you will get the password..
Posted on Nov 15, 2008
  • 685 Answers
What brand is your router?and is your mac desktop hooked up to the router with a wire?
  • 535 Answers
Try this type in your internet explore address bar 192.168.1.1 then press enter
user : admin
pass: admin
then u can configure it
    Brigadier General:
  • 6,966 Answers
Initially, pls postback with the brand/model of the router. Alternately if Windows based, just set the new laptop to automatically "Obtain IP address" inside the TCP/IP Properties of the Local Area Networking or Internet Connection. Another to try is determine the networking numbers used by the MAC which includes IP address, Subnet mask, Default Gateway, DNS servers and enter the same to the new laptop with the exception of the IP address, just do a +1. Example if the MAC uses 192.168.1.11, set the new laptop to use 192.168.1.12, all others stay the same. A hitch though maybe encountered if the router uses WEP, WPA security or MAC address filtering.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 15, 2008
    Based on your recent post, new router, new modem, then perhaps you could try:
    • install the modem first and connect it to your computer using LAN / Ethernet cable;
    • run the CD installer that came with it;
    • verify that that single computer can then access the internet;
    • remove the modem CD installer and put in the router CD installer;
    • follow on screen instructions;
    • connect only the router when instructed to do so.
    Cheers.
  • 19,396 Answers
The password is stored iside the router
  • Ginko
    Ginko Nov 15, 2008
    If the passwor di the wireless key, to access to the router via wireless then you need to connect to the router with a cable.
    Then open router IP using Internet Explorer.
    Log into the router and go to the wireless menu, there you find the key.
    Refer to the router manual to get router IP, router access ID and password, and procedure to access the router control panel using Internet Explorer.
    Scholar:
  • 132 Answers
You may need to access the router's setup page using the working computer to verify the wireless settings, which includes the wireless security enabled in the router. By the way, what is the model of the router you have?
  • Jannette Amandy Nov 15, 2008
    You need to access your router's setup page by launching IE and typing 192.168.2.1 on the address field. If it asks for a password, type the password that you can remember you setup when you first run the setup cd of your Dynex router. Otherwise, just leave the password field blank.
    Once you're in the router's page, click Wireless from Menu then click Security. There you will find the wireless/network key configured in the router.
    Hope this helps!
How do i change my router password and username
You need to RESET router press RESET / WPS button for 10 seconds then all settings defaults . You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. then connect cable from your internet provider to WAN port of router. Let me know if you need further assistance. Thanks for using FixYa.
Jun 27, 2011 | Apple Computers & Internet
My iPhone does not connect to the Zoom X6 DSL modem. I can connect my laptop and a couple other wireless devices but not my iPhone. Is there a setting I should change either on the router or on my iPhone?...
there is 2 possibility 2 change in router first WEP or wpa security code if in your router need password for connect it then you need to find that key code to enter in iPhone.
Second if in router MAC filter is enable then you need to add your iPhone MAC address in allow list of router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
First find the mac address of your iPhone in network setup menu then add that mac id in mac filter of router configuration menu.Then save settings and check.
May 05, 2010 | Zoom X6 (5590) DSL Modem (55900003)
Trying to get on internet but its asking for a wep key or a wpa key I just completed hook up to netgear router have desk top and a wirerles lap top laptop is asking for info
The WEP and WPA key is configured in the router's wireless settings.
WPA is a stronger encryption than the older WEP encryption, I suggest you use WPA or better still WPA2.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 25, 2010 | Computers & Internet
I have just purchased a new MAC and need the WEP password to connect to the internet. How do I get this password? I have a Dell router
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 23, 2009 | Dell Computers & Internet
I am trying to connect a lap top and its asks for encryption key where do i find this key
The encryption key is configured in the wireless router settings.
Nov 20, 2009 | Linksys Wireless-G Broadband Router
Lost the smart wizard installation disc...how do
The wireless router can be configured without a CD by using the IE browser.
2. Start your browser and enter the router's configuration URL IP address. (http://192.168.0.1)
3. Enter the router setup, login and password (default login = admin
and the default PW = password)
Nov 20, 2009 | NetGear WGR614 Wireless Router
I have bought an Apple Mac notebook but am having problems accessing the internet. I think I have inadvertently changed the password to the wireless router as I have succesfully conected my main computer...
This is a confusing report. If you are successfully connecting two other computers to the router using the original router password, why can't you connect your MacBook Pro to the router using the same password? Or is it that the other two computers "know" the original password but you don't?
If one of the other two computers is a Mac, use the Keychain Access utility to look up the stored password for the router.
If not, use one of the other two computers to access the router's configuration screens directly and obtain the password that way.
Nov 15, 2009 | Apple MacBook Pro Laptop Computer with...
I had a earlier problem with my wireless network adapter in my laptop not fully installing. I bought a driver program and now I should have the most updated driver and the driver is working. my continuing...
To configure the wireless router and the laptop's wireless card, follow these steps : -
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 17, 2009 | Linksys WRT160N Wireless Router
Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Gmac
Feb 18, 2009 | Belkin (F5D5231-4) Router
Belkin g router
It doesn't require Mac installer...Please check you have installation cd with you if not... Contact belkin tech support (toll free number) ...They will help you to configure manually...
Feb 18, 2009 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
