Question about RCA CC617 VHS-C Analog Camcorder
Picture rolls on playback
When recording on my RCA 617 all seems to be working well, however, on play back the picture is not stable and it rolls constantly. Will cleaning the heads help this problem. I have tried different tapes and the rolling occurs on the camcorder and when played back on a tv. Thanks,
  • RCA Master
  • 1,650 Answers
Possible causes: the sync signal head is not recording, there is a mismatch between the capstan motor speed and the video head speed, or one of the sync circuits has a fault. Typically, if the picture rolls up or down, it's a vertical sync problem. A horizontal sync fault or tracking mismatch will cause the picture to tear sideways.
Try cleaning the sync head (one of two heads separate from the video head drum; the other is the audio track head), but don't be surprised if doesn't solve the problem.
Posted on Feb 26, 2018
2 Suggested Answers
SOURCE: RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Posted on Oct 15, 2007
The LCD is blue and won't play back . We have cleaned it. Camera mode works when recording. Just no playback picture in VCR mode. ...
you most likely has a bad screen, if you can, play back your video into a VCR, dvd burner or televisino with rca type inputs, this will at least let you save your movies.
Mar 18, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
VHS Video Tape - Picture Roll.
Picture roll is caused by the frame rate being out of sync with the play back device. If the tape was recorded at say 25 f/m and is being played back at 26f/m. If you can, adjust the frame rate until the picture stands still.
Mar 30, 2010 | Philips VRX242AT VCR
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
PV-GS9 mini dv playback problem
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem.
These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera.
However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things worse but I was at a point where I didn't care any more and took a chance that paid off.
Dec 30, 2006 | Panasonic Palmcorder PV-GS9 Mini DV...
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Playback quality problem
A couple of things could be causing the problem. When recording, your movements with the camera could have been too quick or jerky. Try putting the camera on a flat surface or on the tripod and record for 30 seconds. If the playback picture is still bad, then it's possible that the video heads are dirty or worn out. Consult your nearest RCA authorized service center for head cleaning or replacement.
Sep 06, 2005 | RCA CC-432 Camcorder
Video Cameras Logo
85 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
