Question about Kenmore 54501 Dehumidifier
Broken Fan, Lost manual and Parts List
I recently acquired a 54501 with a broken internal fan. The previous owner lost the manual and parts list. If anyone could give it's part # and/or give advice on how to remove/replace the fan that would be great. Also, I searched and searched Sears & Kenmore and could not find any downloadable manual or parts list. Did I miss it or is there any other place where one can be found?
  • InSub Beckley
    InSub Beckley Nov 21, 2006
    I found a tech sheet inside the unit that had some parts listed with directions for disassembly. The new fan motor was $30 plus shipping.
I have the same dehumidifier. Pick it up used off ebay for 60 bucks shipped to me. Works fine. I removed the back cover to inspect the fan and compressor and there was a parts list in a small ziplock bag tapped inside. Take the back cover off and give it a look.
Posted on Mar 26, 2007
As I've recently posted a message, I've a similar unit with broken internal fan. I just placed an external fan in front of the unit and blowing front to back. With the air circulating, the unit is humming along happily and bucket fulls of water to harvest!! Don't bother fixing the fan motor, if that is the only problem, just place a small external fan instead.
Posted on Feb 16, 2007
SOURCE:
Freezes up
most units draw in the front and expel from the rear air , keeping filters clean (never run without one) is important for this function , frost on coils is a sure sign that air flow is low , or might be unit has lost [part of its gas charge due to heat build up from loss of cooling
May 13, 2014 | Kenmore 54501 Dehumidifier
BLOWER WHEEL BROKEN
In your instruction manual you should find a parts list, purchase a new blower wheel and install it. If it is an older unit it may be best to just replace it.
Feb 12, 2014 | Frigidaire Dehumidifiers
Model 580.51450100
Go by a local air conditioner supply house and ask them. Usually if they can't get the part they know where to go to get parts for home appliances like Dehumidifers. Take the fan motor with you they may have something on the shelf that will work.
Jul 15, 2013 | Kenmore 54501 Dehumidifier
A quarter was found in the fan area and one of the blades is broken can i buy a replacement fan cover?
http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=115442
Here is a short list of some replaceable parts for this unit. Which fan are you speaking of here?
Sep 23, 2011 | Maytag M7DH65B2A Dehumidifier
Have a kenmore dehumidifier 42-54501 - I bought it w/o instruction book. Can you tell me where to get instruction book??? Thank You
Since it's a Kenmore ( a Sears house brand) that was made by Whirlpool. You can download the Owner's Manual at Sears Parts Direct or Sears Parts Central.
Hope this helped you, Joe.
Jun 05, 2011 | Kenmore 54501 Dehumidifier
54701 very few running hours. All works but fan wll not run,turns freely no binding. what is the fix??
Number 1 check to see if you have power to fan may have to back track to check switch also check capacitors make sure there are no broken wiresa in fan circut
Jun 11, 2010 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
Aug 09, 2009 | Kenmore 54501 Dehumidifier
Fan
Depending on the ambient temp/humidity and how its set it could definitely run continually. If you don't hear it it's possible the blade is broken or just stuck.
Call 800-243-0000 or go to www.aic.lgservice.com
Dec 25, 2007 | LG LD40E Dehumidifier
Doesn't want to stay on...
Most likely the fan motor has broken. Without the fan, the compressor will overheat. There is a safety device inside that automatically shuts off the compressor to keep the overheating from destroying it. Check to see if you can feel air movement in the front or back of the unit while it is running. If not, then the fan motor has definitely broke. I had this exact problem on mine.
If you take the unit apart, you will find a parts list inside the unit. It will be inside a small plastic pouch. You can order a new fan motor from Sears. The cost is $30 plus shipping.
You will have to move the condensing coil in the front out a bit in order to exchange the motors. Just be careful not to break any of the copper lines. They are copper so they will flex quite a bit without breaking. Still, use caution. If you break the lines, all the refrigerant will leak out and your unit will be useless.
Sep 01, 2007 | Kenmore 54501 Dehumidifier
Help
Check to make sure the fan works. I have one with a broken internal fan and it will appear to work but will not collect water. Do not be fooled by the noise from the compressor. If your fan is broken, the compressor will run until it overheats. There should be airflow that you can feel behind the unit which should be cool and not hot.
Sep 21, 2006 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
261 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
