Compaq Power Led and Speakers connectors
Can you still help me?
  • 3 more comments
  • harp4u Nov 15, 2008
    I already posted the problem regarding Compaq Power Led and Speakers connectors. I only could connect the Power Swithc and HDD. You gave me a link to visit and see some pics that show connectors on the Motherboard. However, I followed the pics and still can't figure out the Speakers and Power Led.
    I am not a geek. I really need someone that can guide me with this cables.
    I appreciate your time and help, thanks.
    The Compaq motherboard model is 06C0h, Pentium 3, Socket 370 FC-PGA, Compaq 686C3. I'm using the pc right now, therefore, I need to turn on/off in order to follow your suggestions. I been working since last night (Thursday) with a magnifier but the MB does not have any labels written on the panel. There are only numbers with letters: FB3, C46, C44, C45, FB3, etc.
    Hope you can find a pic of the same model, thanks.
    Thank you very much for taking the time in helping.
    God bless!
    Hi, I just sent you another comment asking to send me those document to my e-mail.
    Thanks again.
  • JDTec
    JDTec May 11, 2010
    Yes in what issue?
  • 4,338 Answers
Ok on the front panel pin header , you should see 2 pins labeled SPK for the speaker and 2 pins labeled pw led. And also you should see 2 pins for the reset connector. Use a flashlight and /or a magnify glass, the letter may be faint.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 15, 2008
  • 2 more comments
  • JDTec
    JDTec Nov 15, 2008
    If you still have problems, tell me what model is your PC and I will find a picture for you.
  • JDTec
    JDTec Nov 15, 2008
    Here is the documentation, you may have to use your printer to enlarge it.
  • JDTec
    JDTec Nov 15, 2008
    If you have problems viewing it, I can email them to you.
  • JDTec
    JDTec Nov 15, 2008
    My pleasure Hope I can help again in the future.
I cant find the case wireing connections on the motherboard led hhd rw led power and sound were do they go ...and can u send me a pic of how the wires look and were they go thanks
from the Compaq case / cabinet front pannel a single connector will connect to the board.
there will be set of pins / connector with mark" pannel SW / " on the board
It may not mention each seperatly.
May 19, 2011 | Compaq (277500-001) Motherboard
Compaq NX6310. Wont power up. When I press silver ON button the orange LED on front flashes 7 times ...And nothing more. I am measuring 19volts on power adaptor on the inside and outside surfaces of the...
check for damaged usb ports, this can often cause this problem. if you find distorted contacts within the usb port, try to straighten them or isolate them. hope this helps.
Apr 27, 2011 | HP Compaq nx6310 Notebook
I have a compaq nc6000 which wont boot up it trys to fire up then it goes off i have got to run but then it went back to this not booting up
Check and see if your DC connector is loose:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 02, 2011 | Compaq Presario Notebook
Can noy ged moden check shows working t wireless to work ethernet works an- looking for button to turn wireless on . Lookig for actual button to turn wireless on. Do not know where it is at - Thank You
The location of the Wireless ON/OFF switch is on the right hand edge side of the Notebook. Please see image below, it is No. 8
moz-screenshot-2.pngPlease let me know if the information provided has been helpful.
11997_ov.gif 1. Easy Access Buttons (5) 2. Stereo Speakers 3. Touch Pad On/Off Button LED 4. Fixed Optical Drive 5. Touch Pad 6. Primary Battery 7. Wireless LED 8. Wireless On/Off Button 9. Battery Charging LED 10. Hard Drive Activity LED 11. System Power LED 12. Mute Lock LED 13. Volume Controls 14. Headphone 15. Audio In 16. 1394 Port 17. PC Card Slots (1) 18. RJ-11 (Modem) 19. Air Vent 20. Kensington Lock 21. Power Button LED 22. Caps Lock LED 23. Num Lock LED 24. Keypad LED
Aug 20, 2010 | HP Compaq nx9030 Notebook
Need pin configuration for power switch, HDD LED, power LED, front USB, etc.
Hi, just like you I purchased two of these motherboards and I have very good news for you. Above the blue PRIMARY IDE ATA connector is a set of 18 pins labeled PB/LED P5 and pin 1 is labeled.
17 15 13 11 9 7 5 3 1
18 16 14 12 10 8 6 4 2
Pins 1 and 3 = HD LED
Pins 2 and 4 = POWER LED
Pins 6 and 8 = POWER SWITCH
pin 14 has no
Feb 02, 2010 | Compaq (283983-001) Motherboard
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
My m2000 compaq notebook if I power it on the power led will blink three times and went off, it will not display anthing
Charge it first for sometime before powering it up. If it doesn't help. Clean your RAM card with soft eraser only its edge connector. Do it after you disconnect its battery and be sure that its power supply is also not connected to it. Then put eveything back and power it again.
Hope it helps.
Apr 14, 2009 | Compaq Presario M2000 Notebook
PC will not power up
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
Mar 01, 2009 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Need to find out where the on/off cables hook to a 277977-001 motherboard by compaq
Generaly, the little connectors on the printed side will face the bottom of the case. Also, typically, Black is negative, and white/colour is positive (except on the power sw, it doesn't matter). On the motherboard, where the connectors go, there should be some kind of print saying where to plug them in. (IE, POWER SW, would go into PWR, and HDD LED would go into HDLED and POWER LED would go into PWRLED).
It may look different than this, but generally the same kind of layout, as you can see, it shows the positions, as well as positive and negative.
Unfortunetely, I can't seem to find a schematic for the Compaq 277977-001 motherboard. I will try and find one, but I hope this helps you out with what you are trying to do...
Sep 05, 2008 | Intel DG965RY Motherboard
P/N: 283983-001 motherboard
Here ya go fellas... (freakin geeks is really starting to **** and so is compaq/hp for not supplying pdf manuals for this old junk...347ba7a.jpg
Oct 25, 2007 | Compaq (283983-001) Motherboard
Computers & Internet Logo
261 people viewed this question
David Payne
David Payne
